volvo diesel common rail S40 115BHP 2002 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ashby64, this thread has received 3 replies and been viewed 842 times.
post #1 of 4 (permalink) Old 04-11-2007, 07:28 PM Thread Starter
Hi can any one help
On tickover im gettin alot more vibration than usuall and when revinmg its misfires at the start. Just had new glow plugs fitted and glowplug relay, but the problem still persists? Its on 95k miles, had loads of cleaning fluid through it but still running like a bag of spanners. Any suggestions would be much appreciated.
Cheers :bow:
ashby64 is offline
post #2 of 4 (permalink) Old 04-13-2007, 11:37 AM
did you check for any codes in the computer? check the compression? timing off? did you make sure the glow plugs are glowing?
DieselMonk is offline
post #3 of 4 (permalink) Old 04-13-2007, 11:33 PM
Don't tease us in the U.S. I would like a XC90 Diesel. But we can't get that either. Keith
U. S. Navy Seabee Veteran.
We build, we fight , we drink more beer.
When you are up to your butt in alligators it is heard to remember the reason you are here is to drain the darn swamp.
ktpauley is offline
post #4 of 4 (permalink) Old 04-20-2007, 12:40 AM
I'm not sure if that engines utilizes a seperate gilmore belt to turn the injection pump. The older cars had a seperate belt that had tendency to jump a tooth and then the injection pump is not in time. Sounds little injection pump is not in time.
Dave
dieseldave is offline
