My newest Diesel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ymmot, this thread has received 11 replies and been viewed 2868 times.
post #1 of 12 (permalink) Old 05-18-2007, 07:59 PM Thread Starter
ymmot's Avatar
My newest Diesel
Not bad for 228000 miles on it. Steering is a tad loose, but fixable with a $300 steering gear. I'm sure it needs a valve adjustment. I need to really clean out the injectors. It has a coolant dribble which might be a radiator hose or a water pump. All in all it's nice car.
1982 Mercedes 300D with a 3.0l 5 cylinder Turbo diesel.
ymmot is offline
post #2 of 12 (permalink) Old 05-18-2007, 08:24 PM
4cstr
Looks like a nice car Tom. I would love to find something like that to use for an everyday work car.
post #3 of 12 (permalink) Old 05-18-2007, 09:08 PM Thread Starter
ymmot's Avatar
I've found some thing to do it that may bring her up in performance. It seems to lag a bit on the bottom end a bit. Maybe I'm just expecting too much out of 120HP and 170lbs-ft
ymmot is offline
post #4 of 12 (permalink) Old 05-18-2007, 10:50 PM
Diesel Dog's Avatar
Not to forget the 4500lb hunk of steel it's trying to move. I used to have one it was a great car. My only advice is to not try and repair the window switch as this was the first thing I ever found out was actually filled with springs and ball bearrings.
Diesel Dog is offline
post #5 of 12 (permalink) Old 05-19-2007, 01:43 AM Thread Starter
ymmot's Avatar
This one is a 300D not a 300SD Curb weight per the manual is 3500lbs. Still heavy for a car that size.
I think I'v discovered the cause of the coolant dribble. It will run up near the high end of normal. I found a citric acid cooling system flush that is pretty much the same cooling system flush that Mercedes recommends in their shop manuals. I'm going to give that a shot in a couple weeks.
ymmot is offline
post #6 of 12 (permalink) Old 05-19-2007, 03:50 PM
formally dodge97ctd-sc member #12
05dury's Avatar
Send a message via Yahoo to 05dury
does it smoke?
2005 chevy 2500 lly duramax extended cab shortbed 4x4...got some go fast stuff done to it
05dury is offline
post #7 of 12 (permalink) Old 05-19-2007, 04:04 PM
UpstateDieselGuy's Avatar
Nice to see a fellow German Diesel runner. Don't complain about the power. I have a 4 Cylinder N/A Diesel in my VW, however I do have a 5 Speed Look around, there should be a way to turn the fuel up a little. How long before some old Veggie oil? I know my VW loves that old frier oil. I just mix it in with the diesel. Good Luck! Chris
SOLD
UpstateDieselGuy is offline
post #8 of 12 (permalink) Old 05-22-2007, 12:00 PM
TDG Member Since 2004?
KarTek's Avatar
Looks like it's in great shape! Congrats!
-Evan
2000 Ford F250, Merillion, 6sp, AIC, DPTuner, BB turbo, Adreneline pump, modified IDM.
1998 Mercedes E300, Custom injector nozzles, soon to have Eaton M90 supercharger, 7.5mm pump elements, Holset HX40 turbo and a full custom intake and exhaust system = 400HP from 3.0l
KarTek is offline
post #9 of 12 (permalink) Old 05-22-2007, 08:02 PM
I too just bought a 1983 300sd with 148,000 for $3500. It has no rust and my wife loves the thing.
Check out schumanautomotive.com and search for ALDA. It will let you get a little more fuel. I did this to mine and it made a big difference.
Also check out mercedesshop.com. There is a nice article in DIY on how to turn up th boost.
tony597fitter is offline
post #10 of 12 (permalink) Old 05-22-2007, 09:05 PM Thread Starter
ymmot's Avatar
Already a Member over at Schumans.
My ALDA is ajusted all the way out. I'm looking at completely removing it soon. I also need to look at adjusting the wastegate. I'm sure that it is probably not giving me much. Maybe 5 psi at best. The factory spec on the engine is for up to 1 bar which is about 14 psi, although the cars rarely left with more than 7psi from the factory.
On edit: I just filled it up today and it got me 22.9mpg. Pretty good considering I've been hard on the go pedal.
ymmot is offline
