Smoke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Big Gray dodge, this thread has received 8 replies and been viewed 940 times.
post #1 of 9 (permalink) Old 08-27-2007, 01:33 AM Thread Starter
Smoke
I was wondering if anyone new how to turn the fuel up on a 1984 vw diesel rabbit.
Big Gray dodge is offline
post #2 of 9 (permalink) Old 08-27-2007, 10:45 AM
UpstateDieselGuy's Avatar
Look at the Driver's side of the Injection Pump, you will see a screw. The Lock Nut is 13 MM and the Screw is 6 MM. Turning it Clockwise while running will give you more fuel, but be prepared it will Idle higher. Chris
SOLD
UpstateDieselGuy is offline
post #3 of 9 (permalink) Old 08-27-2007, 12:46 PM
yea what he said
SEABEECM1 is offline
post #4 of 9 (permalink) Old 08-28-2007, 12:01 AM Thread Starter
thanks a lot
post #5 of 9 (permalink) Old 08-28-2007, 01:02 AM
No Problem. Chris
SOLD
post #6 of 9 (permalink) Old 10-24-2007, 03:17 PM
Formerly NATTYGASMECH
Canyon JYD's Avatar
Can the 1980 be done the same way?
Canyon JYD is offline
post #7 of 9 (permalink) Old 11-01-2007, 01:54 AM
SmokinCAT's Avatar
If your 1980 has the bosch pump that is the way to do it, if you are worried about the idle look on the top of the pump at the throttle and you should be able to adjust the stop and lower you idle, if you go to far you will have to adjust you cable. I attached a pic of my 1981 rabbit truck, it smokes and was still getting high 30's low 40's and would actually run the speed limit on the freeway.
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #8 of 9 (permalink) Old 11-02-2007, 04:32 PM
Send a message via AIM to shegel
can this also be done to an 86 golf
shegel is offline
post #9 of 9 (permalink) Old 11-03-2007, 12:32 PM
I believe so, take a look at your Injection Pump and see if it is the same. Chris
SOLD
