How to remove PD 130 Passat injectors w/photos - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TooMuchBoost, this thread has received 25 replies and been viewed 5163 times.
post #1 of 26 (permalink) Old 09-27-2005, 08:46 PM Thread Starter
I'll write this up some other time but this is what it looks like.
ID:	1801   Click image for larger version
ID:	1802   Click image for larger version
ID:	1803   Click image for larger version
ID:	1804   Click image for larger version
TooMuchBoost is offline
post #2 of 26 (permalink) Old 09-27-2005, 08:52 PM Thread Starter
The 12 point set is required to remove the rocker assembly and to remove bolt holding the injector holder in place.
As you can see the injectors are a true 90 degrees when correctly installed and they are already 'out' where you see I have them at angle for a better photo of how I removed them.
ID:	1806   Click image for larger version
ID:	1807   Click image for larger version
ID:	1808   Click image for larger version
post #3 of 26 (permalink) Old 09-27-2005, 09:23 PM
How big did you go Andy? And do you need to use the Vag com to balance the injectors? It was unclear if that was needed on the PD's...
NMU98 is offline
post #4 of 26 (permalink) Old 09-27-2005, 09:36 PM Thread Starter
Bigger than Bob's baby!
The injectors are being overnighted in the AM and it's yet to be determined what I'll get in return since this is the first set of over-sized Passat PD nozzles in NA. I have intentionally put myself into a beta situation but I have no fear because I'm in great hands.
Lead, follow or get the flip out of the way.
post #5 of 26 (permalink) Old 09-27-2005, 09:43 PM Thread Starter
The removal really is a walk in the park but you must have the 12pt set (I didn't and had to go see my favorite Carquest manager) and you need something like those little pry bars that I didn't have either ( :bow: thank you Jeff Garmon) to pop the injectors out.
On the way back in the cam lobes need to be at their highest point in the pair that you are installing and you must follow a specific torquing procedure where the rocker arm touches the top of the injector. I'd tell you more but my cheat sheet isn't in front of me.
BTW- Preston was nice enough to offer me bay space for multiple days :thanks: while I waited on the injectors but I just chose to do it in my brother's extra garage where my free loaner was anyway.
post #6 of 26 (permalink) Old 09-27-2005, 09:55 PM
I smell a North (Brian) vs South (Andy) VW hp war brewing......... Forget, Hell!
Timbeaux38 is offline
post #7 of 26 (permalink) Old 09-27-2005, 10:14 PM Thread Starter
Catch me....if you can.
post #8 of 26 (permalink) Old 09-27-2005, 10:59 PM
Andy already has 30 HP on me from stock... And his tranny will take a boat load more than mine.... That is until I put in the GLI clutch... I think that should easily take me to his level...
The more you can tell us andy the better... I know Kerma is the place for nozzles.. and you are in good hands!
So keep the tools, I may need loaner ones.....
NMU98 is offline
post #9 of 26 (permalink) Old 09-28-2005, 03:27 PM Thread Starter
I insured those puppies for $3K and let the big brown handle it from there. They should be back in Friday.
Jeff Garmon has me a little concerned about my current lock-up because according to him it already locks up like a Suncoast with a triple disk in it now with only the stage 3 programming.
We'll see what happens with the injectors and go from there. Jeff at Rocketchip can easily adjust it if its an issue.
Maybe I can get Garmon to put one of his signature lock-up switches on my dash. :smoke:
post #10 of 26 (permalink) Old 09-28-2005, 08:32 PM
I think Jeff needs to do some of his signature Twins under your hood........
Driving the 06 Dodge and Chevrolet DavidTD The Parking Lot 25 08-24-2005 03:28 AM
Dr. Suess For ALOT Of People On Here bigdraft The Parking Lot 7 07-21-2005 03:55 AM
too hot? DieselDadio 1994-2003 7.3L Power Stroke 4 06-08-2005 06:37 PM
North Texas Powerstrokes Loss wideopen General Ford Truck and Excursion 4 06-07-2005 04:10 PM
