1980's BMW Diesel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by genie144, this thread has received 3 replies and been viewed 2267 times.
post #1 of 4 (permalink) Old 04-09-2008, 10:25 PM Thread Starter
1980's BMW Diesel
So who knows anything about these? I am wanting a diesel commuter car and have a line on a '85 524TD with 110k miles. It smokes and the owner says it needs "injector timing" performed... Anyone?
Sam
The Trash Truck
96 CC F350 SRW - Built for SVO and mileage
Go Green - HotFox, Dual Heated Dahl 100s, Fuel Filter Coolant Wrap, ArcticFox
Go Fast - Hybrids, H2E, 6.0 IC, Fuelab, BTS 144.2/291.5 uncorrected
thanx go to
Rockin-S-Performance - Install, tech support, and advice
Diesel Innovations - Killer Deal on Parts
Tony Wildman/SWAMPS - Tuning
genie144 is offline
post #2 of 4 (permalink) Old 04-10-2008, 04:24 AM
ymmot's Avatar
About the only thing I know for sure on the 524TD is that it has a VE pump like what was in the 1st gen Dodge Dummins trucks.
ymmot is offline
post #3 of 4 (permalink) Old 04-10-2008, 04:40 AM Thread Starter
That a good or bad things?
Sam
The Trash Truck
thanx go to
genie144 is offline
post #4 of 4 (permalink) Old 04-18-2008, 02:52 AM
When you say it smokes, what color and does it run poorly with this smoke?
I drove a friend of mines 524TD and it was fast. It also handled good. Yes it does have a Bosch VE pump that is belt driven. Not the best way in my book to drive an inj pump. It is a fuel lubed and cooled type pump. I had a 1980 VW Dasher diesel wagon that used the same type pump but it wasn't turbo'd. The pump was driven off of the timing belt. The pump shaft is just riding in the aluminum bore of the pump case. They do wear but as I did, I had it rebuilt and they put in bronze bushings in the housing. The BMW shouldn't have the belt tension on it that the VW used as the belt only drives the pump.
I would check out the car well before buying it. Remember though that that car, to my knowledge, wasn't really imported to the states. That could make replacement parts either hard to get and/or expensive.
Motorhead is offline
