1999 Jetta GL TDI any issues to worry about? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Gumby, this thread has received 7 replies and been viewed 8319 times.
post #1 of 8 (permalink) Old 01-07-2009, 02:37 PM Thread Starter
Gumby's Avatar
I'm looking at a 1999 Jetta GL TDI 5spd manual with 92000 miles & was wondering if there are any issues/quirks I need to know about. The guy wants $8500 for the car, but KBB says at best it's worth less than $6000. I haven't spoken with the seller yet, just trying to do some homework.
Gumby is offline
post #2 of 8 (permalink) Old 01-07-2009, 02:57 PM
www.tdiclub.com
This is the website I go to for info on my Jetta tdi.
I know a little while back my 2006 was worth more then what I originaly paid for it at the dealership. That was until I pulled out in front of someone and got t-boned. But diesels do hold their value quite well.
wheresmyhat is offline
The Following User Says Thank You to wheresmyhat For this addition to TDG:
Gumby (01-07-2009)
post #3 of 8 (permalink) Old 01-07-2009, 05:02 PM
Supporting Vendor
2nd on TDIclub. Biggest issue is making sure it has had its timing belt replaced on schedule. The OEM one would be good for 60k miles, but you can get a replacement belt and tensioner set which is good for 100k. I love my Y2k TDI. My only gripe is an overly-sensitive glow plug open-circuit detection, which frequently reads a false failure and turns on the CEL. Even if it does not see another failure, the CEL stays on until you reset it through the OBDII port.
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 271k miles
10 ISSPRO Prototype Performax™ gauges in Pillar & Overhead pods & sitting on dash, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps, Swamps tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
32' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
2000 VW Jetta TDI - Kerma tune, Der Chimera Stage II Clutch
NRA member and certified firearms instructor, GOA Life member, IDPA member
Michael is offline
post #4 of 8 (permalink) Old 01-07-2009, 07:11 PM
scotty2280's Avatar
second on the timing belt!
04 6.0, studs,dj fuel +,isspro gauges,sct by eric,4in silverline w/o kitty,HID's, and other odds and ends
scotty2280 is offline
post #5 of 8 (permalink) Old 01-07-2009, 07:30 PM
Supporting Vendor
One more thing - if you turn your own wrenches and can follow directions, you can rent the specialty tools and do your timing belt yourself. The TDIclub forum is full of people who swear that you need a "guru" to do it, but there are some pretty good instructions posted on that forum. I did mine several weeks back. Also put in a clutch, which was a bit more involved (and not as many forum posts explaining it). On a stocker, the clutch should still have plenty of life at 92k, as should the factory brakes.
Regards,
Michael Pliska
Michael is offline
post #6 of 8 (permalink) Old 01-08-2009, 02:47 AM
stillcrazyinlaw's Avatar
Images: 3
just buy a haynes manual and it explains the timing belt in detail. not that hard. I second the CEL for the glow plug thing. other than that good car. The price might be a little high because of the mileage it gets and that is a premium nowadays.
stillcrazyinlaw is offline
post #7 of 8 (permalink) Old 06-01-2009, 06:55 PM
caissiel's Avatar
The timing belt job is an hour job at the dealer and they were going to charged me $500 but I do it in 1 hour in my garage for less then $100 in parts if you change the Idler. I have never changed an Idler yet, on all my VW's. But I had to replace the Idlers on my Mazda, one Idler failed before the Belt did. But that could be because the Mazda had 300K miles on the engine and prior belt changes without the idlers changed.
2005, 6.0L, 6 Spd Std, 3.73 Rear End, 2500SD. Extended Cab, 4 x 4 Long Bed. 2008 extension mirrors. GPS/TV/DVD/CD/Rear Cam/Radio installed. Painted grill and light windows. EGT Gauge, and E-Con programmer by Hypertech. Use a ScanGaugeII to Check/Improve my MPG. Mileage now is 20MPG Highway and 12MPG Towing. Pull a 38ft 15500Lbs 5th Wheel Camper Trailer
caissiel is offline
post #8 of 8 (permalink) Old 08-20-2009, 03:19 PM
Zrock's Avatar
After working in a VW shop for some time. Make sure when you do your timming belt to change the idler and all the pullies in their while you are at it . You can buy the whole kit for not much more than the timming belt itself. out of all teh timming belt jobs we did both blowen belts and just normal maint. It was never the belt that failed it was always a pully that went bad and took out the beld. Even on the ones where it was just time to change the belt their was always a pully thata you could feel the brearings going into it. On the pre 2005 cars we would also recommend to change the water pump as well... It was only a $75 part and no extra labour while we were in their.
Zrock is offline
Lube shop forgot to put my oil cap back on !! After 3500 miles. Should I worry ? LIVIN 2003-2007 6.0L Power Stroke 14 01-23-2008 05:05 PM
When should i worry.... iwannagofast 5.9L Cummins (1998.5-2002) 16 01-12-2008 07:49 PM
worry about this code? willmceliece 1994-2003 7.3L Power Stroke 22 08-11-2006 08:25 PM
For you guys with 07s. Dont worry about the sticker! PSDPlayer 2003-2007 6.0L Power Stroke 11 06-27-2006 01:11 AM
Ordered an 06 VW Jetta TDI NMU98 Euro-Diesels 29 07-09-2005 05:40 PM
