1982 Datsun 720 Diesel white smokes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TLadd, this thread has received 4 replies and been viewed 5996 times.
post #1 of 5 (permalink) Old 01-20-2009, 02:32 AM Thread Starter
Just bought a 1982 Datsun 720 with the SD22 diesel engine. It had been sitting a while and I finally got it to crank up and run. The truck surges at idle and white smokes out of the tail pipe. I checked for bad headgasket, but I don't think it is that because there is no water in the oil and vise-versa and the exhaust smells like diesel fuel. I did an air in fuel test from the injection pump mounted lift pump to the filter and there was no air leak. Right after the glow plugs cycle, it starts right up, but the only issue is that it is blows white smoke out the tailpipe. Any help is aprreciated, thanks.
TLadd is offline
post #2 of 5 (permalink) Old 01-25-2009, 10:51 PM Thread Starter
I sure do appreciate all the responses to my post. Thinking that somebody would know a little bit about these SD22 engines and how to diagnose them. Turns out it was a combination of the fuel filter and an injector. I guess you can't get a good response if you don't have a German-made diesel vehicle.
TLadd is offline
post #3 of 5 (permalink) Old 01-29-2009, 01:51 PM
Bolt
gardentractor's Avatar
sorry i dont know much about them:
2000 F350 4X4 Powerstroke red 6spd reg cab stock for now...
1988 Chevy IROC-Z camaro black 5spd 305 55,000 orig miles, my baby
1988 Chevy 4x4 350 ext long bed
1980 Gmc 4X4 modified 350 k20 flatbed 4spd
1956 6400 Chevy 235 6 cyl
gardentractor is offline
post #4 of 5 (permalink) Old 01-31-2009, 02:51 PM
"White" smoke
From your post, it appears that the "white" smoke may just be unburned fuel. I am assuming it does this when you first start it. If the smoke disappears or is greatly reduced after the engine warms to operating temps, you do not have a problem. This is normal for non-computer-controlled diesels. My Mercedes does the same thing when I first start it cold.
You also might want to check out the intake system; be sure the air filter is new, check all the pipes from the intake to the filter - sometimes critters build nests in the pipes. A good supply of clean air to the engine is essential.
As far as the surging goes, that also may be a function of a cold engine. It should smooth out as the engine warms. You might also check the glow plug system to be sure all GP's are working properly. This would aid in smoke reduction as well as the "stumbling/surging" at cold startup.
Hope this helps....
DagObx is offline
post #5 of 5 (permalink) Old 02-03-2009, 08:46 PM
TDG Member Since 2004?
KarTek's Avatar
At that age, I'd say you probably would do well to replace the injectors or nozzles (if that's an option). Sounds like poor atomization.
-Evan
2000 Ford F250, Merillion, 6sp, AIC, DPTuner, BB turbo, Adreneline pump, modified IDM.
1998 Mercedes E300, Custom injector nozzles, soon to have Eaton M90 supercharger, 7.5mm pump elements, Holset HX40 turbo and a full custom intake and exhaust system = 400HP from 3.0l
KarTek is offline
could sumone please help?? i hav 1982 silverado 6.2 wont turn over vr6vince 6.2L Diesel Engine 3 07-29-2012 06:47 PM
1982 chevy silverado 6.2 electric problems??? vr6vince General GM Truck Forum 5 03-24-2008 09:22 PM
6.2 Diesel White Smoke Problem goldeneyej 6.2L Diesel Engine 3 11-05-2007 07:15 PM
94 7.3 idi smokes 91/2 7.3idi 7.3L and 6.9 IDI (Pre 1994) 4 06-21-2007 03:11 AM
Smokes alot ?????? Mule Man 7.3L and 6.9 IDI (Pre 1994) 3 10-31-2006 06:43 PM
