300SD Pump Fuel Turn Up - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DieselPower, this thread has received 9 replies and been viewed 4453 times.
post #1 of 10 (permalink) Old 12-26-2008, 03:00 AM Thread Starter
2-Stroke God
DieselPower's Avatar
Can anyone do a write-up on turning the pump up on a 300SD without getting a runaway? I put a 300SD engine in a ford ranger for a guy awhile ago and he wants a little black smoke now!
"Not everything that can be counted counts, and not everything that counts can be counted."
- Albert Einstein
How come you guys engines miss every other powerstroke? Your truck, 0 to 180 in 1-2-3-4stroke, My Truck, 0 to 180 in 1-2stroke!
I belive truck boxes are infinitely cooler than 30" rims -You can't store squat in a hubcap.
Cummins Powered Club #3
Dually Club #65
DieselPower is offline
post #2 of 10 (permalink) Old 12-26-2008, 05:59 AM
ymmot's Avatar
What year 300SD engine?
ymmot is offline
post #3 of 10 (permalink) Old 12-26-2008, 01:13 PM Thread Starter
2-Stroke God
1983
- Albert Einstein
Dually Club #65
post #4 of 10 (permalink) Old 12-26-2008, 10:02 PM
flips's Avatar
300SD in a ford ranger
now thats very cool
flips is offline
post #5 of 10 (permalink) Old 12-26-2008, 10:38 PM
ymmot's Avatar
83 has an MW pump. there a FEW things you can do that will pump up the power slightly, but make sure you have gauges.
First is the removal of the rack limiter. What that does is allow you to get full start fuel when the accelerator is pushed all the way down. This is a good write up with pics. You will need to join to see the pictures.
The next thing you can do is adjust the torque control. BE VERY CAREFUL with this is it can cause a runaway scenario.
See pic below:
The picture is of the back of the MW pump.Depending on the placement of your oil filter you will more than likely have to remove the pump. Adjust the torque contorl should be done in 1/4 turn or less increments. The trick is tightening the lock nut back down without undoing you adjustment.
Read here about some other things you can do.
Do be aware the MB has the pump at about 90 to 95% of maximum fuel delivery so you won't gain much. Make sure that the valves are adjusted properly and that IP timing is correct. If you have access to a Bosch tech, you might consider a flow bench test of the pump before you do anything. Also make sure that your injectors are popping at the right pressure and the spray pattern looks good.
ymmot is offline
post #6 of 10 (permalink) Old 12-27-2008, 01:02 AM Thread Starter
2-Stroke God
Thanks, I'll be giving that a go. That's definitely the pump it has.
- Albert Einstein
Dually Club #65
post #7 of 10 (permalink) Old 12-27-2008, 02:29 AM
ymmot's Avatar
One last thing... GET SOME PICTURES AND VIDEOS!!!! I wanna see this thing.
ymmot is offline
post #8 of 10 (permalink) Old 12-29-2008, 01:18 AM
jrmmustang's Avatar
Awsome conversion I to am interestd in it. I wanted to do it cause i have access to a 300 sd. would you share some info or you keeping it a trade secret. Like how hard was it to fit, you use the mercs tranny. How does it run good power good milage come spill the goods
New horse
2003 F-350 Crew Dually 4x4 Auto Cold air intake Silverline stainless 4" turbo back SCT erics x-race,x-street, tow
195k runs good
359.8 hp 6-13-09
14.9-91 mph 7-10-09
SOLD IN ITS PRIME LIVE LONG
1995 CC F-350 292,456 miles auto 4x4 4.10 gears
Intake 4" exhaust 160 cc injectors gauges IDM mod ts redone by "TW" 6 pos
jrmmustang is offline
post #9 of 10 (permalink) Old 04-14-2009, 04:10 AM
I have a 80 300sd. Will this work the same on it
2010 F250, 3in lift 20" procomps. thats it for now
1QKDSL is offline
post #10 of 10 (permalink) Old 04-18-2009, 01:04 AM
ymmot's Avatar
The 80 300SD had the same MW pump.
ymmot is offline
What additives do u add to your fuel??? Carolina Diesel 5.9L Cummins (1998.5-2002) 22 01-13-2009 11:39 PM
fuel line kit? droolinforparts Supporting Vendors Forum 1 12-28-2008 05:29 PM
Solenoid or P pump... Prowler97 5.9L Cummins 12 Valve (1994-1998.5) 6 12-27-2008 11:53 PM
fass fuel pump question droolinforparts 2003-2007 6.0L Power Stroke 10 12-25-2008 09:30 PM
Custom Walbro Lift pump install............ triton Dodge - Modification instructions, Product installs and Tech Articles 0 12-23-2008 07:47 PM
