OK GUYS NEED HELP!!!! Injector pump questions. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Canyon JYD, this thread has received 5 replies and been viewed 1599 times.
post #1 of 6 (permalink) Old 05-22-2010, 10:59 PM Thread Starter
Formerly NATTYGASMECH
Canyon JYD's Avatar
I have 2 injector pumps here and want to put the better one on, if there is a better one. Main difference I have figured out is from a site selling rebuilt pumps. One is said to be for a golf, jetta. The other is for a rabbit. Both manual transmission. I'm hoping some guru on here can identify if the golf, jetta pump is any better than the rabbit pump? The other info I have found out is that they are supposed to be the same plunger size. ALSO what is the difference in a VE R 66 and a VE R 185?????? Here are the numbers from the pumps.
Golf, Jetta - VE R 185
0 460 494 161
068 130 110 G
Rabbit - VE R 66
0 460 494 117
068 130 109 C
(Quote: M123KT-450) "That's what happens man it's hard to Damage steal with tin foil ! "
Canyon JYD is offline
post #2 of 6 (permalink) Old 05-23-2010, 02:07 PM
Not sure, try asking over at tdiclub.com.
D-Cell_Mekanick is offline
post #3 of 6 (permalink) Old 05-24-2010, 02:48 PM
Zrock's Avatar
The easiest way to find out is just look up the engine spec's for both veh... Im asuming the golf/Jetta will be the bigger pump if i remember corectly they had teh slightly larger engine. Would help to know what years
Zrock is offline
post #4 of 6 (permalink) Old 05-28-2010, 04:00 AM Thread Starter
Canyon JYD's Avatar
OK GUYS. Didn't want to try at TDI FORUMS cause those guys don't have any interest in N/A diesels, also they are not as willing to accept off topic conversation as we are here. Did it anyway. No such luck. They seem more interested in what do you tow? Spank it!
Don't have the info on year make model. I need someone who know these things. Someone who can say oh yeah ###### means, and ##### means, this. I've tried high and low. There got to be someone on the web who knows!!!!!!!!!!!!!!!!!!!!!
post #5 of 6 (permalink) Old 07-14-2010, 10:00 PM
The Rabbit pump is for an NA(normally aspirated) engine. Since I am new on this site I wasn't allowed to put any links in this reply.
mvptrukin is offline
post #6 of 6 (permalink) Old 07-14-2010, 11:24 PM
The middle set of numbers is the important one. The 6th digit is the plunger size ,in both of the pumps 9 is for 9mm. The 7th digit is for application i.e. 4-4 cylinder, 6-cylinder etc.A good source for VW diesel info is www.vwdiesel.net .The forum is in French and English and has a TDI side and a IDI side. Just look in the FAQ for VE pump info. The TDI guys are just like the TDIclub.com boys, a bunch of direct injection snobs! --Long live IDI!
Injector pump questions Lunchbox 7.3L and 6.9 IDI (Pre 1994) 4 11-26-2009 07:45 PM
6.2 Heavy Duty Injector Pump Questions??? JLanzino 6.2L Diesel Engine 6 10-08-2009 01:41 AM
I need an injector pump and a lift pump for a 98.5 24valve CRAZY ROB Whats Been Sold 7 07-01-2009 11:15 PM
Injector Pump and Lift Pump are toast. Now What? 6thFrame 5.9L Cummins (1998.5-2002) 21 05-19-2009 09:32 PM
More pump and injector questions monstercrew 5.9L Cummins (Pre 1994) 4 01-28-2007 03:17 AM
