help identify this diesel engine? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gogo55, this thread has received 11 replies and been viewed 2905 times.
post #1 of 12 (permalink) Old 08-14-2010, 09:04 PM Thread Starter
Can anyone help me identify this engine? or help me where to look to find out more about it?
It's in a 1967 Ford truck chassis, that is a step van.
it's a inline 6 cylinder diesel, but I can't seem to find a data plate or any info on it.
gogo55 is offline
post #2 of 12 (permalink) Old 08-14-2010, 09:05 PM Thread Starter
Here's a picture of it
gogo55 is offline
post #3 of 12 (permalink) Old 08-14-2010, 09:09 PM Thread Starter
Here are 2 more pictures.
gogo55 is offline
post #4 of 12 (permalink) Old 08-15-2010, 11:05 AM
Fahlin Racing's Avatar
I can check my manuals to see if I have anything that covers this year. Is this medium duty?
Jim "Iron Giant" Fahlin ~ A high performance car is like a guitar, you have to tune it to achieve your best operation and pull ahead of the competition.
Gas & Diesel Motorsports
Heavy Equipment/Truck/Trailer parts Specialist
Zeigler Diesel Perf
Socal Diesel
Fahlin Racing is offline
post #5 of 12 (permalink) Old 08-15-2010, 08:09 PM Thread Starter
Yah.
also.. from what I can read on a different placard, it says 116HP at 2800 rpm.
gogo55 is offline
post #6 of 12 (permalink) Old 08-19-2010, 04:34 AM Thread Starter
After doing more research, I'm thinking this may be a detroit engine? Any resources for trying to find out more?
gogo55 is offline
post #7 of 12 (permalink) Old 08-19-2010, 06:34 AM
Euro Sparky/ Wrencher
french277's Avatar
Ce n'est pas un moteur Detorit du tout il regarde plutôt Perkins autrement une vieille école le moteur de tracteur de diesel de Ford là-dedans un des deux mais je penche plus vers à Perkins.
Si vous avez pris une photo de pompe d'injecteur je peux capable de dire lequel.
That is not a Detorit engine at all it look more like Perkins otherwise a old school Ford diesel tractor engine in there one of the two but I am leaning more toward to Perkins.
If you took a photo of injector pump I can able tell which one.
Merci.
Marc
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
french277 is offline
post #8 of 12 (permalink) Old 08-22-2010, 12:44 PM
I want to say Perkins. See if you can locate any casting numbers, logo etc. If it is indeed a Perkins, its a Chrysler product. As far as finding a stroke length, only do this if you think its necessary, take an injector out, have a rod to fit into the injector orifice and get the cylinder to TDC. Mark the rod as it sits and rotate the engine until BDC and mark the rod again. Measure the distance to give us a general realm of where the stroke might be close to. I know its not accurrate 100% but it will give us a direction to a point. Unless you decide to rebuild this rig, don't bother with the rod through the injector hole. Hope this helps.
Zeigler Diesel Perf
Socal Diesel
post #9 of 12 (permalink) Old 08-24-2010, 09:34 PM Thread Starter
more details
Ok, I found some more info.
Looks like it is a Ford. After some more cleaning I found a logo that looks like it has F M C in the logo. It was on the valve cover... But it's kinda hard to tell what exactly it says.
Still not 100% sure. I can find many details online. Should I be searching for old ford farm engines?
here are some more pics.
gogo55 is offline
post #10 of 12 (permalink) Old 08-24-2010, 09:38 PM Thread Starter
Found it.. search for Ford 2703E brought up the engine.
Thanks!
gogo55 is offline
Can anyone identify these turbos? Blownbbf Medium and Heavy Duty 1 09-21-2009 05:44 AM
New Diesel Engine: Buck Marine Diesel timbillyosu General Diesel 19 07-17-2009 05:00 AM
Trans Identify? EB.Bldr 5.9L Cummins (2003-2007.5) 12 04-09-2009 05:46 PM
Trying to identify an engine noise. ovruigo 5.9L Cummins (2003-2007.5) 18 01-22-2009 03:14 PM
Help me identify this... 99fordtruckguy 1994-2003 7.3L Power Stroke 1 04-03-2008 12:01 AM
