Fuel priming - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2500ctd, this thread has received 5 replies and been viewed 1849 times.
post #1 of 6 (permalink) Old 10-14-2010, 03:56 AM Thread Starter
Fuel priming
I ran my new project out of fuel and need help getting it restarted. Not going as easy as my 01 Dodge last time I did that. However this one is a 1980 Volvo. How do you reprime a mech injection pump?
2500ctd is offline
post #2 of 6 (permalink) Old 10-15-2010, 06:04 PM
I have an air tank about two gallon size, I fill it with fuel about 80%, I have two female, couplings one in each end. I charge the tank with shop air, then couple it to the inlet side of the pump. I hold the tank up and open the valve to back flush the fuel into the tank. then shut it off I have a gauge in the line. I usually tap into the banjo fitting on the inlet side of the pump. Even if the lift pump will not allow the fuel to return, it will pressurize the injection housing and bleed the air from the injection pump allowing it to start.
Johnp3 is offline
post #3 of 6 (permalink) Old 10-16-2010, 03:48 AM Thread Starter
Do I need to crack the injector lines as well? Thanks for the info.
2500ctd is offline
post #4 of 6 (permalink) Old 10-16-2010, 04:02 AM
If you can keep preasure in the pump you can do that, charge the battery and only crank for 15 seconds at a time then wait for at least a minute. Most engines will start with 1 or 2 cylinders bled, do not use any starting aids, either, you can take a rag and damp with Gas and put it on the air cleaner, that will up your cranking speed.
Just a thought!
Johnp3 is offline
post #5 of 6 (permalink) Old 10-29-2010, 09:07 AM
BlowinSmoke's Avatar
Just thought I'd share my experience running my truck out of fuel. Truck is same as my signature. I had my buddy tow me to a gas station and we filled the fuel tank full. What I was trying to do was see how many miles I could push a tank of diesel. Anyways with the tank full all I did was crack each injector fuel line separately and cranked til fuel came out meaning the air was out of that line. I cranked no more than about 10 seconds for each line. After bleeding the sixth line like that the truck fired right up.
Best of luck getting it started
BlowinSmoke is offline
post #6 of 6 (permalink) Old 10-29-2010, 04:51 PM
With a P7100 pump you will more than likely not hurt anything, BUT you really do not want to do that, without the fuel there is no lubricant in the barrels and plungers, it will stay wet enough I would think but.
Johnp3 is offline
help!! fuel priming NIGHTMARE. dazman Duramax 2001-2004 (LB7) 3 01-29-2011 05:41 PM
fuel pressure question? fuel filter or over flow valve? hereismylife 5.9L Cummins 12 Valve (1994-1998.5) 23 04-09-2010 12:33 AM
83 GMC 6.2 priming question ps147243 6.2L Diesel Engine 10 06-18-2009 01:40 AM
466 priming procedure drillerjr Medium and Heavy Duty 3 05-25-2009 01:38 AM
Fuel priming help grimey 7.3L and 6.9 IDI (Pre 1994) 8 04-16-2009 05:52 AM
