need help with old 4 cylinder diesel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fox440, this thread has received 19 replies and been viewed 3053 times.
post #1 of 20 (permalink) Old 01-31-2011, 07:37 PM Thread Starter
so me and a buddy took a independant study class. we decided we would get an old diesel engine running that we had laying around our school shop. if we can get it going we may convert it for biodiesel. the motor is on a stand right now, it has everything it needs to run ( the shop teacher used to teach a class where he would show how a diesel engine works and he had the engine running, so we know it runs its just been sitting for about 10 years). we found a plate with what looks like the manufacturer specs and stuff on it but it was in a different language, so this tells me it must be a foreign diesel engine. i was wondering if this engine should have glow plugs? and what should we do to get this thing going? i can supply more information if needed i will also try to get some pics of it.
Nick
fox440 is offline
post #2 of 20 (permalink) Old 01-31-2011, 07:57 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
Pictures would be good, it might be a Russian implement engine
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 20 (permalink) Old 01-31-2011, 08:45 PM Thread Starter
i will try to get some pictures tommorow. the writing on the engine looks rusian
fox440 is offline
post #4 of 20 (permalink) Old 02-01-2011, 04:19 AM
turbo??
GLXpress is offline
post #5 of 20 (permalink) Old 02-02-2011, 01:52 AM Thread Starter
no no turbo, here are some pics. can you guys tell me everything you can about this engine.
ID:	28109   Click image for larger version
ID:	28110   Click image for larger version
ID:	28111   Click image for larger version
ID:	28112   Click image for larger version
fox440 is offline
post #6 of 20 (permalink) Old 02-02-2011, 02:23 AM Thread Starter
someone on another forum said its out of a vladimirski traktor. is this right?
fox440 is offline
post #7 of 20 (permalink) Old 02-02-2011, 02:53 AM Thread Starter
i found this site on it if it helps also
http://tyres-parts.net/product_info....f41d8818c9bb74
and one more question, how would i go about turning this thing off once i have it running??
fox440 is offline
post #8 of 20 (permalink) Old 02-02-2011, 02:57 AM
TDG Mafia Goon
BombDocDiesel's Avatar
It looks like a Russian copy of an old Deutz. To kill it, cut fuel or air. Air would be easier with just a slide in the intake tube running off the front of the motor.
It does not appear to have glow plugs.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #9 of 20 (permalink) Old 02-02-2011, 03:06 AM Thread Starter
okay thanks. also how would i prime this engine, there is no fuel in it so i know i will have to fill up the fuel filter with diesel but i am not sure where the filter is.. there are 2 containers that the fuel line runs through before getting to the injectors but there was no filter in either containers, does this mean this motor just doent use a filter? i thought maybe someone just took the filter out but it dosnt even look like a filter is supposed to be in them?
fox440 is offline
post #10 of 20 (permalink) Old 02-02-2011, 03:11 AM
TDG Mafia Goon
That looks like a priming pump on the back of the injection pump. The little WIF housing on the back of the filter block seems pretty simple. If that's not a priming pump on the injection pump I would be surprised.
Does the fuel return line on the back of the block go to anything? I see the rubber hose sitting there. Is that the fuel supply line? I can't tell from the pic but the return line may go back into the filter block.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
1 Cylinder Down... PSD Trav 2008-2010 6.4L Power Stroke 18 07-27-2010 08:46 PM
where is cylinder #1 okiebindernut 2003-2007 6.0L Power Stroke 12 03-07-2008 03:27 PM
06-24-4 6.0l - Service Remanufactured Engine, Cylinder Block, And Cylinder Head Ident Squatch Ford Oasis requests 0 03-22-2007 02:52 AM
2006 6.0L Diesel Power Stroke Cylinder Head Commonization PSDPlayer 2003-2007 6.0L Power Stroke 11 05-19-2006 08:31 PM
1992 F-700 6 cylinder diesel mjoiner Medium and Heavy Duty 15 04-04-2006 08:51 PM
