poping flames out exhaust? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mel8030, this thread has received 1 replies and been viewed 3083 times.
post #1 of 2 (permalink) Old 06-11-2011, 11:40 PM Thread Starter
4 cylinder diesel inline injection pump tractor was left idling unattended and ran out of fuel. Now when it runs at higher RPM, it pops flames out of the exhaust. Runs ok at slower speed. What could cause this? I have never seen a problem like this before. Maybe tight exhaust valve and running out of fuel has nothing to do with problem?
mel8030 is offline
post #2 of 2 (permalink) Old 06-12-2011, 04:51 PM
I would do a valve set, change the fuel filters, and put it to work for a while if the problem persists then you can remove the exhaust manifold looking for a dead cylinder or remove the injectors and test them, and do a compression test, and or Cylinder leak down test.
It is very rare that any problem will be caused from running out of fuel.
Johnp3 is offline
door poping o8fordcompletlystock 2008-2010 Body & Suspension 4 08-11-2010 02:30 PM
poping out of gear in 4WD 96stroker 1994-2003 7.3L Power Stroke 0 05-03-2008 07:31 PM
Flames out of exhaust? Superdutytd General Diesel 10 04-27-2008 06:36 AM
poping sound bluestroker 2003-2007 6.0L Power Stroke 4 05-30-2007 12:41 PM
Exhaust Flames fordfanatic69 General Ford Truck and Excursion 6 11-29-2006 05:22 PM
