4-71 detroit engine? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rodney R, this thread has received 1 replies and been viewed 3087 times.
post #1 of 2 (permalink) Old 07-31-2011, 04:32 PM Thread Starter
Looking at a 4-71 engine, and somebody mentioned that early models are not worth near what late model engines are that there would be different parts associated with each. So this got me to wondering - the only number that I can find is on the block, and is 5183376, and that is cast into it. I Have been search the web, but I have found no info on this motor, so any advice is appreciated.
Rodney
Rodney R is offline
post #2 of 2 (permalink) Old 08-01-2011, 04:16 AM
There is a pad with the serial number, and model number on it you want to find that.
They are a very tough engine and can be rebuild multiple times. You want to remove the valve cover, and see if it is a 2 valve or 4, also is it a dry block, there is also an earlier version called a low block.
With the casting number a Detroit parts department can tell you that.
Johnp3 is offline
6.2 detroit torence20 6.2L Diesel Engine 7 05-18-2011 02:41 AM
Bad Azz Detroit 4cstr The Parking Lot 4 02-09-2011 01:48 AM
need help identifying this detroit engine 86 1 tonhauler General Diesel 5 04-21-2008 12:06 PM
471 4-71 Detroit Engine 1964reo Whats Been Sold 4 12-25-2007 03:00 AM
8v71 Detroit Truck Engine (adding To Website) King of Obsolete Medium and Heavy Duty 5 05-24-2006 12:26 PM
