Air in the fuel?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by GLXpress, this thread has received 5 replies and been viewed 1576 times.
post #1 of 6 (permalink) Old 02-12-2012, 02:09 PM Thread Starter
Air in the fuel??
My Ford tempo with the Mazda RF diesel ain't been running right last few days. Starts fine, idles fine, but when I get 1/8-1/4 mile from home I lose power and bout dies then it will take off and run $hi**y for awhile but by the time I get to the edge of town (~7miles) runs fine.
I fired it up friday and you can see air bubbles rolling thru the line from the fuel filter to the IP.
What would cause this?
GLXpress is offline
post #2 of 6 (permalink) Old 02-28-2012, 04:20 PM
nitrogen's Avatar
all it takes is one tiny fitting/hose with a tiny vacuum leak. could be seal on pump shaft?
Canadian Club #31
nitrogen is offline
post #3 of 6 (permalink) Old 02-28-2012, 11:08 PM Thread Starter
so whats the best way to fix it?
Lift pump???
GLXpress is offline
post #4 of 6 (permalink) Old 02-29-2012, 03:43 AM
nitrogen's Avatar
Tighten all the fittings on the suction side, look for worn shaft seals. If you don't find any loose fittings then maybe pull the line off the pump, block it at the fuel tank and then pressurize it gently maybe 5-15 psi and see if you can make it leak.
Canadian Club #31
nitrogen is offline
post #5 of 6 (permalink) Old 10-04-2012, 04:23 AM
nitrogen's Avatar
ever find anything?
Canadian Club #31
nitrogen is offline
post #6 of 6 (permalink) Old 03-12-2013, 06:48 PM Thread Starter
I put a little electric diaphragm pump in the trunk above the tank
Sent from my SCH-R930 using Tapatalk 2
1984 Ford Tempo GLX
2.0L Mazda RF diesel (factory)
140k miles and counting
GLXpress is offline
fuel pressure question? fuel filter or over flow valve? hereismylife 5.9L Cummins 12 Valve (1994-1998.5) 23 04-09-2010 12:33 AM
Alt Fuel! Tired of Traffic? HOV lane Bi-fuel F150! - $10000 taztruck Whats Been Sold 0 01-04-2009 04:13 PM
LLY Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:38 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 2 ripmf666 GM Spec Info 0 12-28-2008 11:37 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:24 AM
