oil temperatures - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 4 replies and been viewed 1028 times.
post #1 of 5 (permalink) Old 06-03-2015, 01:16 PM Thread Starter
Dodgefarmer's Avatar
oil temperatures
Just wondering what is the optium temperature for engine oils. My 2013 6.7 cummins runs 197-199* at 70-75mph. That seems high for optium lubrication(run delo 15-40). (One thing I noticed is rpms has a bigger impact on temps compared to load. Run the same temp if towing or not, but drop a gear or two at same speed temp will go up some.) Or do manufactures let it run this high to gain a percentage point or two in fuel economy. I know on hydraulic systems on equipment I build or run we keep oil at 180 or less.
So whats the best temperature for lubrication vs economy?
What do others see in oil temperatures? (maybe a poll here?)
singles club # 198
Dodgefarmer is offline
post #2 of 5 (permalink) Old 06-10-2015, 07:53 PM
Pardue the Traveler
New 0mega's Avatar
197-199 is on the high side. You might want to consider having the engine coolant checked to see if it's doing its job. If its okay then you might want to consider checking the oil cooler.
Singles Club member #250
New 0mega is offline
post #3 of 5 (permalink) Old 06-14-2015, 02:39 PM Thread Starter
My coolant runs 188-190* I think the Thermostat is 190 as you can see the temp bounce between 188 and 190 as it opens and closes.
I still think its an economy thing because I have shot oil temps on the filter with an infared gun on some later model engines in equipment and they are also running close to 200*
singles club # 198
post #4 of 5 (permalink) Old 06-15-2015, 02:50 AM
Weld engineer's Avatar
Those temps are chilly on a 6.0. We easily see 215 and as high as 230 oil temps on our engines. I think the flash point is around 250 so you are no where near the danger zone. I would agree it's an economy, emissions strategy to keep things hotter.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following User Says Thank You to Weld engineer For this addition to TDG:
Dodgefarmer (06-15-2015)
post #5 of 5 (permalink) Old 06-15-2015, 02:02 PM
ADMIN/MAFIA
neeltburn's Avatar
My coolant temp can reach as high as 210* on a hard pull, but Im one of the lucky ones with a 200* tstat. No oil temp gauge yet,on my 12. The reason you see higher temps than normal is due to emissions. Mike you will have warning lights when oil temp is out of range. However, I do not believe you are anywhere near the danger zone as Wes stated 6.0s run HOT.
Sent from AutoGuide.com Free App
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
Temperatures bear1 2003-2007 6.0L Power Stroke 20 06-18-2013 07:41 PM
Question about EGTRA temperatures/Fuel Mileage Truckmaniac 2008-2010 6.4L Engine Tuner Forum 7 01-22-2010 01:26 AM
Slack adjuster grease for low temperatures. todd2008 Medium and Heavy Duty 3 12-07-2009 12:47 AM
Temperatures rufcut 2003-2007 6.0 Tuner Forum 7 04-21-2009 04:28 AM
Normal Operating Temperatures? Trbotime 2003-2007 6.0L Power Stroke 7 02-12-2008 05:08 PM
