Fuel algae, what to do - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skypilot, this thread has received 1 replies and been viewed 297 times.
post #1 of 2 (permalink) Old 08-23-2017, 01:50 PM Thread Starter
I have a diesel powered boom lift that is seldom used. I filled the 30 gallon tank 3 years ago because a full tank is suppose to be better as far as air space in the tank. Well it took me 3 years to get down to 5 gallons and now I see algae thru the fill spout on the tank. I drained the tank but still see the black stuff in the bottom. I screened what I drained and got some there also. I don't use it near enough to fill it again. I'm thinking of putting in 5 gallons at a time but then there is the air space problem. It is impossible to get access to the inside to clean it and there is nowhere open on top to put a clean out access. It is a poly tank and I can't even see much thru the fill hole. I would like to know what the best additive on the market is to try to kill this algae and then how should I go about fueling it in the future for occasional use. How much fuel at a time? What additives to put in the fuel. Can you use, lets say stabil and a biocide at the same time? I will be constantly checking the inline filter and the spin on on the motor often now of course. I will be cutting them open and monitoring it from now on. Any suggestions to help me clear this up and prevent more of it in the future would be appreciated.
skypilot is offline
post #2 of 2 (permalink) Old 08-24-2017, 08:57 PM
Jasong's Avatar
It's not the easiest thing to find, but there is nothing like "Pri-D" when it comes to stopping algae.
It will also prolong the life of the fuel.
Jasong is offline
black algae!! dondiesel444 Medium and Heavy Duty 12 02-03-2013 04:45 PM
Alt Fuel! Tired of Traffic? HOV lane Bi-fuel F150! - $10000 taztruck Whats Been Sold 0 01-04-2009 04:13 PM
LLY Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:38 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:24 AM
Algae Killer Info maxxis_mudder 2003-2007 6.0L Power Stroke 2 02-13-2006 06:30 PM
