Cummins 4BT - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 350FORD, this thread has received 4 replies and been viewed 1395 times.
post #1 of 5 (permalink) Old 05-31-2006, 05:52 PM Thread Starter
350FORD's Avatar
Cummins 4BT
Where can I find info on this motor ? My understanding so far is its a the same as a six but with two cylinders cut off. Still need more info, any help would be appreciated
03' F350-DRW, SB
SCT TUNES BY DOUG, MBRP, INTAKE
174, 940 mi.11/16/11
bcbsupply.com
350FORD is offline
post #2 of 5 (permalink) Old 06-01-2006, 12:09 AM
might try the http://www.cummins.comCummins site
We had several of 4BT Cummins they are a awsome lilttle motor in dozers, trackhoes& self propelled packers most hp ive seen out of em was 110hp w/ the turbo i know they ran on the firto lay trucks for years .
there is a farmer here @ home he has a 4BT RATED round 100 to 110hp in a 83 Chevy 1 ton sevice truck he put in after his 454 went kaboom he found 1 of the ole chip truck in a junk yard in Mo & everything lined up (he beefed his front end some though) he might be a litlle slow but his ole bowtie is strong as an ox if it was my truck i wouldnt be scard to take it anywhere .
also http://www.fordcummins.com has the conversion kits to covert the cummins 4b & 6b Cummins in the blue ovals
Hope this helps & have a safeone
Mack
B422T Mack is offline
post #3 of 5 (permalink) Old 06-01-2006, 02:41 AM
RCFFD #47
Send a message via AIM to DBogo
best place to find them is in either old frito lay vans, older construction equipment and tractors but the frito vans are the automotive version
1995 Ram 2500 12v NV4500 4x4, 5" ss straight piped , ICEBOX, #10 place, 215 injectors, 4.5gsk, afc full forward, cranked starwheel, autometer boost/pyro, jacobs exhaust brake, 60lb springs, boost elbow, KDP tabbed, HID's, DT Profab +1/2" control arms, silencer ring MIA, air horns
1988 Mack RD690, 300, 8spd, 17' Bibeau dump, electric tarp, leds all around, 2 stage jake, 6" straight stack, the 'ol dog barks
1983 VW Rabbit Pickup, 1.6 N/A, 5spd, stock for now
The Desire to Serve, The Ability to Perform, The Courage to Act 100% Volunteer
DBogo is offline
post #4 of 5 (permalink) Old 06-01-2006, 08:51 PM
Down With The Slickness
Send a message via AIM to Deezle1
The same mods apply as a 12 valve dodge...u can use the same injectors etc if it has a inline pump and is an 8 valve...:evil:
a figment of you're imagination...
1997 dodge ram 1500 4x4 318 auto: summit ignition, fastman throttle body, holley fuel pump 23lb injectors, 180* high flow t stat, open element intake, 3 inch cat back exhaust out the side, high flow water pump, high pressure oil pump...needs trans.
87 Chevy K30 6.2 4x4 4 speed...restoration/build
Deezle1 is offline
post #5 of 5 (permalink) Old 06-02-2006, 02:26 AM
Smokem's Avatar
That was a hint, shoot for the off road version of the engine.
Smokem is offline
