6-354 Perkins - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cep, this thread has received 5 replies and been viewed 3721 times.
post #1 of 6 (permalink) Old 12-13-2007, 03:23 PM Thread Starter
cep
6-354 Perkins
We have completely rebuilt a 6-354 Perkins.
Everything was done to spec. but we are only getting slightly over 200lbs compression.
Any ideas of what may be the issue?
Any and all feedback will be greatly appreciated.
Thanks,
Lance
cep is offline
post #2 of 6 (permalink) Old 12-14-2007, 02:47 AM
Do You Have The Same On All Of Them ?? You Can Do A Leak Down Test With Air And Check It Thanks
1964reo is offline
post #3 of 6 (permalink) Old 12-14-2007, 06:51 AM
Euro Sparky/ Wrencher
french277's Avatar
is the comppresion reading the same all 6 cylinders ??
there are few thing in my mind what can cause low compression.,
did you the OEM or aftermarket cylinderhead gasket ?? [ some have diffrent thickness it will affect the commpression.
what the cranking speed you are getting about ??
to read good commpression you need to spin at least min of 200 rpm on this type of engine.
some Perkins engine do have compression relase lever on it [ not all have this so just keep in your mind watch out with it ]
did you gap the piston rings at 120 apart ?
[ this is pretty picky on this item ]
very rare but it do happend wrong piston in there as well.
Merci, Marc
french277 is offline
post #4 of 6 (permalink) Old 12-27-2007, 03:54 PM
What horsepower does this engine make: 131 hp @ 2,800 rpm?
Gillig8V71 is offline
post #5 of 6 (permalink) Old 01-01-2008, 05:04 AM
I put the compression rings in upside down (once), after about 100 miles I pulled it back down and had two looks. Second noticed the shape on the end of the ring.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #6 of 6 (permalink) Old 01-01-2008, 08:17 PM
Valve Adjustment Or Incorrect Cam Timing . Possibly The Wrong Pistons.
imported_ESJDIESEL is offline
