need help identifying this detroit engine - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 86 1 tonhauler, this thread has received 5 replies and been viewed 1395 times.
post #1 of 6 (permalink) Old 04-15-2008, 03:53 AM Thread Starter
i have this detroit engine in a grove sprayer with very low hours like 300hrs
and it has a detroit in it and was maybe considering puttin this engine in my 86 f-350 i have pics of the engine if this would help i would need to know also about how much hp and tq this engine is puttin out and what trans would mate up to this engine , any help would be greatly apprecated very much thanks 86 1 tonhauler:thanks:
i can take more pics of the engine or get number off the side of the block if anyone needs them
Name:	dt engine.jpg
ID:	15450   Click image for larger version
Name:	dt engine3.jpg
ID:	15451   Click image for larger version
Name:	dt engine4.jpg
86 1 tonhauler is offline
post #2 of 6 (permalink) Old 04-15-2008, 11:29 PM
take a photo of the valve cover and the other side so for all i can do istell you it is a detroit diesel maybe a 53 series
theakerstwo is offline
post #3 of 6 (permalink) Old 04-18-2008, 03:44 AM
2-Stroke God
DieselPower's Avatar
That is a 3-71 Detroit. It is probably running about 90 to 115 HP right now. I ran one in a 76 F350 with a 13spd and loved it. But I had ceramic X-Head pistons, 127mm injectors, fast timing, holset VGT, 6-71 oil pump, home-made bypass, intercooled, Jakes, 4 valve head etc. Remove the valve cover and let us know if it's two valve or 4 valve, and what injectors it has (HV6, N65, N70??). Then I can tell you a little bit more about it. Also there should be a tag on the valve cover. Give us all the numbers of of that.
Lawrence
"Not everything that can be counted counts, and not everything that counts can be counted."
- Albert Einstein
How come you guys engines miss every other powerstroke? Your truck, 0 to 180 in 1-2-3-4stroke, My Truck, 0 to 180 in 1-2stroke!
I belive truck boxes are infinitely cooler than 30" rims -You can't store squat in a hubcap.
Cummins Powered Club #3
Dually Club #65
DieselPower is offline
post #4 of 6 (permalink) Old 04-20-2008, 10:11 AM
Euro Sparky/ Wrencher
french277's Avatar
C'est a 4 -71 due i can able count the fuel port plugs
Merci,Marc
french277 is offline
post #5 of 6 (permalink) Old 04-20-2008, 10:24 PM
hard to tell by pics but looks like a 4-71
rbaker6336 is offline
post #6 of 6 (permalink) Old 04-21-2008, 12:06 PM
2-Stroke God
Yeah, it could be a 4, but I know it's a 71 by the water pump and oil cooler.
- Albert Einstein
Dually Club #65
