detroit 453 oil consumption - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by firehillbilly, this thread has received 18 replies and been viewed 2719 times.
post #1 of 19 (permalink) Old 02-02-2009, 12:52 AM Thread Starter
resident mason
firehillbilly's Avatar
we got a 453 turbo that burns about 3 qts oil a day. its in a Clark 667 skidder. Some people we've talked to say this is normal but it seems a little excessive. Anybody run one ?
06 Sierra 2500 4wd lb. Predator, S&B, MBRP duals-no cat, Quadzilla gauges, Allison Jr., Riderite air bags, PPE Tie rod sleeves, egr plate / finger stick. 02 Chevy 3500 8.1L 4wd dump 9' Fisher mm2, sander. 03 Kubota L4630. 80'S or 90's Komatsu pc50. 89 d250 5.9 which may someday go into something.:
firehillbilly is offline
post #2 of 19 (permalink) Old 02-02-2009, 01:03 AM
Euro Sparky/ Wrencher
french277's Avatar
Combien d'heures ont fait le moteur torturé en haut jusqu'ici ?
Typiquement ils utilisent 1 à 3 litres d'huile de lubrifiant un jour selon le poids d'huile et tempture.
How many hours did the engine racked up so far ?
Typically they use 1 to 3 liter of lube oil a day depending on weight of oil and tempture
Merci,Marc
french277 is offline
post #3 of 19 (permalink) Old 02-02-2009, 01:09 AM Thread Starter
resident mason
we don't know how many hours are on it. temp outside is below 0 to 30 above and engine temp never comes off cold on gauge. also if it isn't warmed up for at least 15-20 min it'll make a severe rap at rpm. oil dripps out of breather tube on left side of motor but not 3 qts worth.
post #4 of 19 (permalink) Old 02-02-2009, 01:41 AM
french277's Avatar
Si vous avez l'huile 15W-40 s'attendent utiliser si beaucoup je n'entrerai pas à la partie 10W-30 à tout {trop mince d'huile de lubrifiant pour Detorits}
If you have 15W-40 oil expect to use that much I will not go in 10W-30 part at all { too thin of lube oil for Detorits }
Merci,Marc
The Following User Says Thank You to french277 For this addition to TDG:
firehillbilly (02-02-2009)
post #5 of 19 (permalink) Old 02-02-2009, 01:44 AM Thread Starter
resident mason
what about 20w-50?
post #6 of 19 (permalink) Old 02-02-2009, 01:52 AM
french277's Avatar
Originally Posted by firehillbilly View Post
what about 20w-50?
20W-50 ? Non., trop épais pour cela
20W-50 ? No , too thick for it
Merci,Marc
post #7 of 19 (permalink) Old 02-02-2009, 01:59 AM Thread Starter
resident mason
so we just keep buying oil then? thanks-Neil
post #8 of 19 (permalink) Old 02-02-2009, 07:57 PM
M123KT-450's Avatar
SAE60 lasts the longest in a detriot I've used a ton. . .
Detriot are knowen to be oil consuming Leaking burn POSes. . .
You could walk threw a truck stop years ago n new who was running a 71 or 92 sieres Detroit by the large Oil puddle under the truck. . .
A detriot that always low on oil i would pay no mind to just fill it up with some SAE60 or cheapo 20w-50 and keep running it. . .
The DT that dosn't use oil is the one that would make me worried. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
The Following User Says Thank You to M123KT-450 For this addition to TDG:
post #9 of 19 (permalink) Old 02-02-2009, 10:25 PM Thread Starter
resident mason
That seems to be the common answer. 20w 50 or 60 not to heavy for winter though?
post #10 of 19 (permalink) Old 02-02-2009, 11:23 PM
M123KT-450's Avatar
Nope them Diesel will oump that SAE60 perfectly as cold as -10 *F. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
Help cat 3126 oil consumption John P Medium and Heavy Duty 12 04-08-2008 09:28 PM
7.3 oil consumption highboy diesel 7.3L and 6.9 IDI (Pre 1994) 5 11-13-2007 02:51 AM
Oil consumption oldmikegraham 1994-2003 7.3L Power Stroke 12 11-04-2006 10:09 PM
Oil Consumption bigdraft 1994-2003 7.3L Power Stroke 15 03-06-2006 01:09 AM
