external trans filter and housing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Robts, this thread has received 4 replies and been viewed 1467 times.
post #1 of 5 (permalink) Old 03-06-2009, 04:05 PM Thread Starter
Supporting Vendor
Robts's Avatar
Looking for an external transfilter housing like the one from suncoast. I only need the housing and bracket. Dont need lines. Im making my own
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/forum...read.php?t=933
Robts is offline
post #2 of 5 (permalink) Old 03-06-2009, 04:17 PM Thread Starter
Supporting Vendor
Robts's Avatar
can I use this
http://cgi.ebay.com/ebaymotors/HD-Ex...spagenameZWD1V
Twin turbos
Robts is offline
post #3 of 5 (permalink) Old 03-06-2009, 08:55 PM
SSpeeDEMONSS's Avatar
sure, looks fine to me.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #4 of 5 (permalink) Old 03-07-2009, 07:14 PM
Dodgefarmer's Avatar
I would check with NAPA. They have several different remote filter housing. See what fits the best. The ebay ad they are using a motor oil filter. The PH8A fit nearly all dodge older V8 and slant 6s motors. You could even screw on a taller filter that is 1.5 times taller. I forget the part number.
singles club # 198
Dodgefarmer is offline
Robts (03-08-2009)
post #5 of 5 (permalink) Old 05-07-2009, 06:15 AM
I paid 1/2 that at the HD parts counter, my Dodge uses 1/2 in cooling lines, hydraulic pressure lines work well to hook things up with a safety factor of 1000 or so and good oil resistance.
JC Whitney used to sell an oil filter relocation set with a second casting to go where the engine oil filter came from the factory - that way you get the hoses, filter mount and fittings.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
External Trans. filter mount Spike 64 5.9L Cummins (2003-2007.5) 2 01-03-2009 07:17 PM
Can someone direct me to the external trans filter? Sader123 2003-2007 6.0L Power Stroke 2 03-17-2007 10:15 PM
sneak peak on new oil filter housing & fuel filter housing hhrecovery 2003-2007 6.0L Power Stroke 42 02-17-2007 04:39 PM
5r110 External Filter. Where? sredish 2003-2007 6.0L Power Stroke 24 03-10-2006 03:29 AM
External Tranny Filter ??? jschall 2003-2007 6.0L Power Stroke 12 11-28-2005 12:35 PM
