High Altitudes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ccxnola, this thread has received 5 replies and been viewed 1922 times.
post #1 of 6 (permalink) Old 05-14-2009, 05:41 AM Thread Starter
High Altitudes
I did not find an answer after searching, so I'll ask:
For a TEMPORARY time in high altitudes (Denver and west) during a trip, should I plan to do any adjustment to the running mode on my 100% manual 1997 Cummins c8.3? (in a MoHo) I am hoping that I can get by with some loss of power for a few days and just live with it - BUT if I do need to make adjustments before getting a mile-high, I need to know about it. Thanks in Advance
ccxnola is offline
post #2 of 6 (permalink) Old 05-15-2009, 02:45 AM
Fire App. Mech.
Should not even see loss of power (the turbo compensates for the lack of air) except at low RPM where the turbo is not effective, but seeing as you have an automatic it should not be an issue. If you see loads of rolling black smoke in the mirror then you should back off till it clears up but I doubt it is an issue at all.
Birken
Birken Vogt is offline
post #3 of 6 (permalink) Old 05-15-2009, 03:27 AM Thread Starter
Thanks
Birken,
Thanks for the reassurance - I'm sure the big trucks do not make motor adjustments every time they go back & forth across the USA, but I just recently read that the c8.3 should have adjustments for high altitude. I guess that is for regular use up high!!
ccxnola is offline
post #4 of 6 (permalink) Old 05-16-2009, 06:20 AM
Euro Sparky/ Wrencher
french277's Avatar
Normalement la plupart de réserve le diesel à moteur turbo est évalué le pouvoir bon en hausse de 10,000 pieds {3,050meter}, mais une fois que vous devenez susdits qui numérote le niveau de pouvoir diminuera de là.
Gardez juste dans votre avis l'évaluation de pouvoir(puissance) fera(sera) pour varier un peu selon ce que le manufacter coucher à et l'HP évaluant aussi.
Si vous avez l'HP très élevé l'évaluant peut affecter plus que l'HP bas évaluant le moteur {baised sur le même bloc-moteur}
Si vous avez besoin de plus de renseignements braillent juste un d'entre nous vous aidera à vous donner corrigent information dont vous avez besoin.
Normally most stock turbodiesel have rated power good up to 10,000 feet {3,050meter} but once you get above that number the power level will fall off from there.
Just keep in your mind the power rating will varies a bit depending on what the manufacter set at and the HP rating as well.
If you have very high HP rating it may affect more than low HP rating engine { baised on the same engine block }
If you need more info just holler one of us will help you to give you correct information you need.
Merci,Marc
french277 is offline
post #5 of 6 (permalink) Old 05-16-2009, 10:58 AM
bushpilot's Avatar
i think youre probably used to driving a "gasser"....the mixture (air / fuel) of
a carburated engine would benefit from adjustment but a diesel doesnt really
need that.
youll be fine....
a diesel performs BETTER w/ a "rich" (more fuel) mixture...where
a gasoline motor does the opposite.
Gasoline engines run "stronger" when theyre on the "LEAN" side (a lean gasoline
motor will get HOTTER too though), to cool a gasoline motor you add more
fuel (making it richer).
a RICH running diesel motor will build more heat (exactly opposite of a gasser), take
away the fuel & youll cool the diesel.
Keep an eye your EGT's when your in the higher altitudes and pulling the longer
grades. If the EGTs start climbing you should be able to 'regulate' the EGTs
by slightly lifting your foot slightly off the throttle.
Don R.
Truck Audio,
bushpilot is offline
post #6 of 6 (permalink) Old 05-17-2009, 03:00 AM
Ol Dirt Contractor
Lowboy's Avatar
The newer electronic diesels just cut the fuel rate back (derate) at high altitudes. This saves the turbo from over speed (less intake loading from the thinner air) and keeps EGT's down.
You can do the same thing with your foot, just watch the egt's. I run my Cat motor from 4000' to 9000' almost daily but I'm usually conservative with the throttle up high.
I was Anti-Obama before it was cool!
Leno: ‘Remember the Old Days When Obama’s Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage III’s, H2 for now, Wide Open Performance long block. Spearco Intercooler 4” downpipe Suncoast Tranny, Terminator Oil
Newest--2015 Black VW Golf SportWagen TDI DSG Nav Roof 18" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L CAT 3406E 5DS Borg Warner 175963 Turbo P5 Nathan Horns Johnson Matthey 600 HP DPF 2017 CA registered emissions legal
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline
egt to high SOOTBANDIT 6.7L Cummins (2007.5-2011) 13 04-02-2009 08:26 PM
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 01:36 PM
rpm not going high enough exoticsrnw 5.9L Cummins 12 Valve (1994-1998.5) 3 03-07-2008 05:41 PM
High 7.3 hp dlopp Dyno Board 6 03-06-2008 10:59 PM
High egt help iwannagofast 5.9L Cummins (1998.5-2002) 12 11-24-2007 05:38 AM
