To loose them or not(stacks) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Robts, this thread has received 16 replies and been viewed 1743 times.
post #1 of 17 (permalink) Old 06-07-2009, 03:15 PM Thread Starter
Robts's Avatar
As much as I love them my stacks they are driving me nuts. It wasnt that bad with the 6leaker but the cummins is f'n loud. I cant hear my daughter in the back seat yelling at me to tell me to switch her movie. I think alot has to do with the last few weekend driving to these events. YEsterday I spent 11 hours in the truck. We left at 6am and arrived at noon to leave at 530 and drive back....I was going to add a muffler, which I have a few MBRPs laying around but Im thinking of ditching them. Ive talked to a few and they admit the cummins is one loud motor un muffled. So
Should I loose them and add an exhaust or not
This means I can run a hard cover and do a cut through over the winter for my stereo....
Just looking for responses
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/foru...read.php?t=933
Robts is offline
post #2 of 17 (permalink) Old 06-07-2009, 03:30 PM
Banned
I took mine off last fall. I loved the looks and the smoke shooting up in the air. But the people that had to ride in the back were always *****ing about it. I had one good friend tell me seriously you don't realize how annoying it is in the back seat. So I went back to my cool duals with no cat and no muffler.
wastedwagesracing is offline
post #3 of 17 (permalink) Old 06-07-2009, 03:36 PM
Robby Thompson
ReconDieselPerformance's Avatar
I have a buddy of mine that just added a muffler to his single stack so his baby could ride in the truck. He seems to be happy with it and so does his wife and yungun.
ReconDieselPerformance is offline
post #4 of 17 (permalink) Old 06-09-2009, 02:26 PM
Administrator
fordt's Avatar
Images: 5
I loved my stacks on my 450, but had to remove them for the noise. IMO, if you are going to be traveling, and you get the added benefit of a hard cover, go with a single, or duals out the side. Maybe even in front of the wheel, to be a bit different.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #5 of 17 (permalink) Old 06-09-2009, 02:46 PM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
After adding the Aero Turbine with the resonator helped for me.
POWER STROKE 99 is offline
post #6 of 17 (permalink) Old 06-09-2009, 03:24 PM
TDG Mafia #76
John_DeereGreen's Avatar
A resonator does a WORLD of good for that Cummins sound. Give that a try first...if nothing else it might help from pissing all your neighbors off when you go back to the sidewalk smoker...
Jarrett
04.5 qcsb commonrail
Smarty TnT
John_DeereGreen is offline
post #7 of 17 (permalink) Old 06-09-2009, 03:33 PM
I had dual 6" straight pipes on my Kenworth (N14), when I hit the Jake brake it was so loud it blurred my vision
I installed dual resonators under the truck and slide-in baffles in the stacks to calm things down.
Check with Grand Rock to see if they make the slide-ins for that short of a stack (mine were 8' long)
BONE STOCK
444turbodiesel is offline
post #8 of 17 (permalink) Old 06-19-2009, 02:54 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
I like stacks too, but they can be a PITA! As nice as your truck is and I know how you keep it spotless, it really is up to you. My 05 has 5" silverline with a muffler and it is still loud as hell. You are going to have to put a resonator on it and a muffler to keep the stacks to keep it decent in the cab on long trips. Probabaly going to have to do the same stuff with regular exhaust as well. And I wouldn't exit it before the rear tires, it is a PITA to keep clean. We did that on a DRW and a SRW. The DRW was worse but either way it sucks cleaning soot off.
Putco light bar
Dieselwrencher is offline
post #9 of 17 (permalink) Old 06-28-2009, 04:57 AM
Dinner's Avatar
How high are your stacks in comparison to the cab? I've read that some people have raised them a couple/few inches and it made a heck of a difference.
But I agree with others, a Resonator or some sort of Muffler would probably help out quite a bit.
2001 Dodge 2500 4X4: Goerend, TST, Smarty, MVP, BD Rad, Injectors, Two Turbo's, Snow Performance, Supporting Mods...
12.7 @ 108mph Aug 2011
Canadian Club Member #14
Dinner is offline
post #10 of 17 (permalink) Old 06-28-2009, 05:06 AM
Diesel Kid
Super08Duty's Avatar
Dont ditch the stacks. Keep them and just add a good muffler.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
Things you loose the most..? blackcloudCTD95 The Parking Lot 45 09-11-2007 02:38 AM
Loose box....? BigRed97 1994-2003 7.3L Power Stroke 7 08-02-2007 04:26 AM
Loose Belt?? Paxamus 2003-2007 6.0L Power Stroke 20 12-13-2006 09:27 PM
Steering is a little loose worktruck 2003-2007 6.0L Power Stroke 21 05-26-2006 02:29 AM
