Nozzle tester - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fahlin Racing, this thread has received 5 replies and been viewed 3913 times.
post #1 of 6 (permalink) Old 08-05-2009, 12:38 PM Thread Starter
Fahlin Racing's Avatar
Nozzle tester
Ok, so I bought some "new" tools from an in-law this last weekend and I recieved a Diesel Nozzle Tester from Kent-moore J-29075-B. He said he used it mainly for Mack injectors, but, could it be used for other makes?
Thanks,
Jim
Jim "Iron Giant" Fahlin ~ A high performance car is like a guitar, you have to tune it to achieve your best operation and pull ahead of the competition.
Gas & Diesel Motorsports
Heavy Equipment/Truck/Trailer parts Specialist
Zeigler Diesel Perf
Socal Diesel
Fahlin Racing is offline
post #2 of 6 (permalink) Old 08-06-2009, 01:37 AM
What ever will bolt on......it is the adapters that make life so interesting
Go get the scandel sheet and see what hey think the machine will do, and a TIG welder will make the rest
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 6 (permalink) Old 08-06-2009, 12:41 PM Thread Starter
I will try and find it. Thanks.
Zeigler Diesel Perf
Socal Diesel
post #4 of 6 (permalink) Old 11-21-2012, 10:33 PM
Man. Trans 2wd Enthusiast
reviving the thread.
Is this member still active, and if so, is the Kent moore tester for sale? I found out they work on 6.5L diesels, and I need to rebuild some injectors (needed to for a while, but its finally getting inconvenient enough to have the truck down to finally do something about it! )
if it is for sale, would you happen to have the accompanying J-29079 adapter kit?
kinda a long shot seeing how the thread is this old, but any response appreciated!
99 Chev C3500 6.5L NV4500 14 bolt 2wd 4.10 130K White Ext, Gray Int. RC159.5" WB DRW Chassis Cab with utility box Runs Great, building up
96 GMC C2500HD 6.5L NV4500 14 bolt 2wd 3.73 240K White Ext, Blue Int. ECLB 155.5"WB SRW Pickup runs bad, getting motor right now
95 GMC C2500HD 6.5L NV4500 14 bolt 2wd 4.10 135K White Ext, Grey Int. RC 131.5"WB SRW Pickup with utility box runs strong, yet huffs on 1 hole
95 Chev C3500HD 6.5L NV4500 D80 2wd 5.13 132K White Ext, Grey Int. RC 159.5"WB DRW Chassis Cab with flatbed bad heads, needs motor re-do
94 GMC C2500HD 6.5L 4L80E 14 bolt 2wd 3.73 300K White Ext, Blue Int. Suburban needs engine
91 GMC C1500, 6.2L SM465 10 bolt 2wd 3.42 59K Red Ext, Red Int. RCLB 131.5"WB SRW Pickup needs injectors, oil cooler lines
91 Chev C1500 4.3L 5LM60 10 bolt 2wd 3.42 ??K White Ext, Red Int. RCLB 131.5"WB SRW Pickup needs...alot
Dad's:
98 GMC C3500 5.7L Vortec NV4500 208K down right now, needs head gaskets (dex cool claims another set! )
92 GMC C3500HD 6.5L Turbo NV4500 160K needs exhaust system and oil cooler lines
93 GMC C3500HD 6.5L Turbo 4L80E 260K had a crate 6.5L sometime
All above are 159.5" C&C, 10'-12' flatbed, Summit white, RC, SL trim, 2wd
96 GMC C2500HD SL ECLB 6.5L 5spd 2wd. 215K (sold to dad, ran good for a bit, started missing at idle, had blowby since purchase
84 Pete 362 COE, 300 BCIII RTOO 13 spd Fuller (3 OD ratios, hard to find) Single axle tractor, air seats, cab, suspension, OEM twin 200 gallon tanks.
74 Pete 352 COE, cat, 13spd TS, B&H grain truck
90 Marmon 57P long hood conventional, 60"flattop, 12.7L60 Series, 13 spd fuller, TS tractor
76 Marmon COE 8V92T 13spd fuller, TS B&H grain truck
95 IHC 9600 COE M11, 10 spd, SA tractor.
GM Guy is offline
post #5 of 6 (permalink) Old 11-21-2012, 11:44 PM Thread Starter
Yeah, I am still kickin' around. However I have done the research on this particular tester and its obsolete, all the new adapters will not work either, so a welder is the best tool if I decide to fork out the money for a few hundred dollar adapter set. As far as which kit it is, its not at my home to check which one it is. However though, I don't plan on selling it for now, Sorry bud.
Zeigler Diesel Perf
Socal Diesel
post #6 of 6 (permalink) Old 11-29-2012, 06:48 PM
thanks for replying!
there is a J-29079 adapter set on e-bay right now, and individual adapters under that same number (the kit is officially J-29079-125, but IDK if its labeled as such) maybe that will get you the adapters you need?
good luck with it!
Dad's:
GM Guy is offline
Looking for a good roll around batter charger/tester/jumper. Lonesome7.3 The Parking Lot 2 05-30-2009 10:53 AM
Info needed: 7.3L injector balance tester. harleyengineguy 1994-2003 7.3L Power Stroke 0 03-08-2009 10:26 PM
Battery Tester VONDIESEL General Ford Truck and Excursion 1 12-14-2007 02:12 AM
Has anyone checked out where u can be a tester for edge? BigFordOn24s 2008-2010 6.4L Engine Tuner Forum 4 06-09-2007 08:53 AM
Nozzle Location? Blksmokejunky 2003-2007 6.0L Power Stroke 11 04-02-2007 02:15 PM
