Question: Fuel Shut off Solenoid - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bushpilot, this thread has received 9 replies and been viewed 8912 times.
post #1 of 10 (permalink) Old 08-24-2009, 02:27 AM Thread Starter
bushpilot's Avatar
So ive got a little project in mind & Im wondering if i can use a
fuel shut off solenoid <to control fuel flow, from the cab>
any suggestions on for a CHEAP 12 volt "in line" fuel shut off
solenoid that i could or should use.
Am i correct in assuming that the solenoid would NORMALLY be
closed <no flow> when 12v is not present ?
Im also interested in a small INLINE fuel pump <doesnt have to do
a lot of volume>...any suggestions there would be helpful too.
Don R.
Truck Audio,
bushpilot is offline
post #2 of 10 (permalink) Old 08-24-2009, 06:08 AM
Only a couple of things come to mind for a fuel valve with remote control.
First is a tank change over valve with the 2nd tank fitting capped.
Local hydraulics house they have NO and NC.......about the same money. Or a propane supplier, that is probably where they buy theirs or an industrial like McMaster-Carr.
Proof of concept can be found in dishwashers/washing machines for much less money, most are viton/nylon. For the difference in price you can own a couple of little inverters.
Small pumps - a cheap electric fuel pump, paid $42 last month for 7# 145 L to replace a leaky mechanical pump.
Cheap? Ball valve, spring and a pull cable
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 10 (permalink) Old 08-24-2009, 04:06 PM Thread Starter
bushpilot's Avatar
not interested in ball valves or cable op., or anything that isnt 12v.
anyone know where i can get something like this -
The SV series is a normally closed valve that opens when connected to
a battery DC supply. Removal of power to the solenoid - e.g. via a Murphy magnetic switch or other engine fault control circuit - causes fuel shut off and engine shutdown.
SV series valves can be used in a range of engine control and fault protection applications.
Don R.
Truck Audio,
post #4 of 10 (permalink) Old 08-24-2009, 09:17 PM Thread Starter
bushpilot's Avatar
BUMP
Don R.
Truck Audio,
post #5 of 10 (permalink) Old 08-24-2009, 09:31 PM
Banned
I see it's made in England..Maybe Tech Guy can find you a hook up.
wastedwagesracing is offline
post #6 of 10 (permalink) Old 08-24-2009, 09:39 PM Thread Starter
bushpilot's Avatar
theres GOT to be something similar in our own back yard...its a SIMPLE 12volt solenoid,
opens and closes to allow or prevent fuel flow...simple stuff.
Don R.
Truck Audio,
post #7 of 10 (permalink) Old 08-24-2009, 10:18 PM
Banned
post #8 of 10 (permalink) Old 08-24-2009, 10:23 PM
Banned
http://shopping.murcal.com/Catalog/D...Shutoff-Valves
Now I suppose they don't have it in your color....
post #9 of 10 (permalink) Old 08-24-2009, 10:31 PM
********* and Mafia #90
Bcarriveau's Avatar
Adding a Controllable return line.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #10 of 10 (permalink) Old 08-24-2009, 11:33 PM Thread Starter
bushpilot's Avatar
now why you gotta be like that
67 bucks seems "spensive" to me...i like the 1st one <probably
cant rebuild it though>...and im guessing for all the RE-BUILD kits
out there, you MUST have to rebuild 'em on ocassion.
no actually im looking at some improvements over my RDS gravity fill / splice,
it stuck "open" ONCE (in the driveway) and now im paranoid !
Don R.
Truck Audio,
Fuel Solenoid Meister 5.9L Cummins 12 Valve (1994-1998.5) 24 07-27-2007 02:54 AM
fuel shutoff solenoid R-muck 5.9L Cummins 12 Valve (1994-1998.5) 13 04-29-2007 02:04 AM
Fuel Shut Off Solenoid Problems Bone stock 99 5.9L Cummins 12 Valve (1994-1998.5) 8 01-18-2007 04:43 AM
EGR vs VGT Solenoid Question shelby_hauler 2003-2007 6.0L Power Stroke 4 05-25-2006 07:32 PM
shut off solenoid refuse2 Medium and Heavy Duty 8 12-04-2005 02:17 AM
