Questions about a throttle repair - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 2 replies and been viewed 747 times.
post #1 of 3 (permalink) Old 09-10-2009, 10:51 PM Thread Starter
One of my deuces has a throttle issue that I think will be easy to repair. I just need a better understanding of what I am up against. The truck runs and starts fine and will move when you let out on the clutch. But there is no response when you step on the throttle. If I push down on the throttle pedal it will return to its original position. Before I crawl underneath can someone tell me what I should look for? Does this sound like a common problem?
post #2 of 3 (permalink) Old 09-10-2009, 10:53 PM Thread Starter
Okay, I crawled underneath and found the problem. The linkage is pulling back but the piece that sticks out of the injection pump is stuck. I could not get it to loosen by tapping it with a hammer. So what should I do next? Is this something I can repair without pulling the injection pump?
ID:	21806   Click image for larger version
ID:	21807   Click image for larger version
post #3 of 3 (permalink) Old 09-10-2009, 10:57 PM Thread Starter
I pulled the passenger side fender for easier access. I zeroed in on the problem area. I do not know what that part of the IP is called, but I o know it does not work. Can any one offer me any tips or tricks before I proceed?
ID:	21812   Click image for larger version
ID:	21813   Click image for larger version
Repair Manual killsme General Dodge Discussion 11 07-17-2011 05:56 PM
clearcoat repair dodgefarmer2 The Detailing, Paint & Bodyshop 2 07-22-2009 12:04 AM
Does your mouse need repair? Chobeeman The Parking Lot 10 05-06-2009 09:54 PM
Need help with E brake repair I10HaulR 1994-2003 7.3L Power Stroke 1 08-13-2007 02:30 AM
track bar repair kit masonjo 5.9L Cummins (1998.5-2002) 1 11-08-2006 03:43 AM
