diesel warmup? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ehopp88ss, this thread has received 11 replies and been viewed 2375 times.
post #1 of 12 (permalink) Old 05-10-2010, 04:35 AM Thread Starter
2004.5 Dodge Ram 2500
ehopp88ss's Avatar
diesel warmup?
hey guys,
my dad and i am currently in a heated battle. lol. he says i dont need to warm up my truck in the morning before driving to work.
is this an ideal process? or am i just wasting fuel?
thanks
erik
Erik
My Vehicles
2004.5 Dodge Ram 2500 4X4 QCLB, NV5600, 177K miles, 10000k HIDS, FASS 150, EDGE juice w/ attitude "HOT UNLOCK", VALAIR 650HP DD thanks to DAN'S DIESEL PERFORMANCE!
1988 Monte Carlo SS, 305 SBC, true dual 2.25" t-304 Stainless exhaust, T-Tops, custom red pryzmatique paint, 2 12" Alpine Type-R Subwoofers, 500 Watt Alpine amp, Alpine speakers inside, complete 2 year ground up restoration, 22K miles on rebuild
ehopp88ss is offline
post #2 of 12 (permalink) Old 05-10-2010, 04:56 AM
Gone Fishin...
merlin5577's Avatar
Your wasting fuel. Just start it, wait until you have oil pressure, then drive. If you idle the engine to warm it, the rest of the drive train is still cold and stiff when the engine is ready to go, plus the wasting fuel part...
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
The Following User Says Thank You to merlin5577 For this addition to TDG:
ehopp88ss (05-10-2010)
post #3 of 12 (permalink) Old 05-10-2010, 05:04 AM
Wasting fuel, once it has full oil pressure the best warm up is a 20-30% load. An exhaust brake will do the same as driving very gently.
If you are next to the get on ramp and the traffic is fast, a trip around the block is better than idling 5 min.
I think that a cold start is about the same as a 100 mile run, whether it is to move into the garage or run all day for another 800 miles. I lived for a while where a loaf of bread was 70 miles and no traffic, another place the get on ramp was 2 blocks, the traffic heavy and getting in line took 80 mph min - worriesome with the choke on.
Cold idle is the worst wear condition for a diesel - not enough pressure behind the top ring to seal properly and the cylinder wall will not evaporate any fuel on the cylinder wall so it washes down into the engine oil, somewhere 1000 - 1200 rpm the pressure seals the upper ring.
The warm up comes from engine designs out of production over 60 years
81 Isuzu /C223na, 5spd
keydl is offline
post #4 of 12 (permalink) Old 05-10-2010, 01:28 PM Thread Starter
ehopp88ss's Avatar
even in extreme cold i shouldnt idle it for at least 5 mins? i live in illinois and it gets kind of cold here.
Erik
My Vehicles
post #5 of 12 (permalink) Old 05-10-2010, 05:11 PM
Gone Fishin...
merlin5577's Avatar
Correct. Just start it up, and once you have oil pressure, drive it gently at first, then like normal.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #6 of 12 (permalink) Old 05-10-2010, 05:27 PM
One thing I learned living in Alberta is to start an engine when it is real cold crank it for 10 seconds wait for 60 seconds and it will start. To warm it up quickly run it at low idle for 30 seconds then at 1000 for 90 seconds, low idle for 10 then shut it down for 60 seconds that allows the heat in the exhaust, to go into the cylinder head and when you restart it is amazing the difference in tempature. Then you should be good to go as was mentioned progressive shift and I was always taught to give it a surge in reverse first. I use to stay in a low gear for a while to be sure everything is lubed up. Just a thought!
Johnp3 is offline
The Following 2 Users Say Thank You to Johnp3 For this addition to TDG:
ehopp88ss (05-10-2010), Frankieneedsadiesel (05-19-2013)
post #7 of 12 (permalink) Old 05-11-2010, 02:29 AM
For the most part i let it go for 5 min, then gentaly go till its up to full operating temp. Might be wasting alittle fuel but i know oil got everywere before taking off.
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
The Following User Says Thank You to budtoh3zo For this addition to TDG:
ehopp88ss (05-11-2010)
post #8 of 12 (permalink) Old 05-11-2010, 07:11 AM
When the oil pressure is up to normal it is time to raise the engine speed to 1k rpm to see that the oil will flow if it is COLD - I started one at -30 and the oil would not build pressure in the normal 30 seconds. I shut down and got a salamander to point at the pan, 20 min and the oil pressure came up, 2 min to build air and the transmission would not shift into gear. Just about an hour late it worked normal. It was a truck that I picked up from auction in S Texas and that afternoon the engine and all gear boxes were changed for winter oil, next day -no problem.
Part of the maintenance is knowing that the seasonal maint is current, it is more comfortable to go back in the warm for an hour while the engine warms but it costs money in fuel, wear, and extra maint labor. The only diesel that I ever 'warmed' was an NTC in a Transtar that leaked all the air in 6 hours, the compressor was slow starting so the first tank of air for the day took 20 min unless it was cold, in the low 20's it took 40 min to get 70 #. After that it worked normal so I did not take much apart to find the problem.
Cranking for 10 - 15 seconds warms the batteries chemicaly, warm batteries work better.
keydl is offline
post #9 of 12 (permalink) Old 05-11-2010, 09:15 AM
Superdutytd's Avatar
Images: 3
I've never thought that a little bit of warm up time was a bad thing. 2-5 minutes when its really cold for the oil temps to come and up the truck to smooth out a bit.
2008 Red CCSB 6.4 Auto Lariat.
Stock 20's wrapped in 35x12.50R20 Toyo MT's, 3.73 gears, Nav, Backup Cam, Tailgate step, Upfitters, etc.
Mods: AFE Intake, Line-X, 20% Tint, Clear Bra, Husky Mats, Smoked Recon Mirror markers/3rd brake light, Bushwacker Pocket style flares w/ mud flaps + an aluminum Rapid Hitch (one of the best investments!)
Feel free to PM with any questions about any of my mods.
SRW Club #55
American Club #55
Last road trip-567 miles @ 20.7 mpg @ 67mpg average speed.
Superdutytd is offline
The Following User Says Thank You to Superdutytd For this addition to TDG:
post #10 of 12 (permalink) Old 05-12-2010, 05:14 AM
There is no doubt that heading into traffic with an engine stumbling along on 3-4 cylinders is just not an excellent plan. That was the point of taking the long route to the on ramp, if that is your current situation. Mine is 4 miles to the pavement, where there is a little traffic, it was not always that way for me, either for my personal transportation or the 3 window office.
keydl is offline
Attention california diesel owners... Diesel smog testing is coming soon!!! N_P General Diesel 1 04-09-2009 12:58 PM
2005 warmup questions gator Duramax 2004.5-2005(LLY) 1 01-18-2009 05:07 PM
Opinions on using the warmup valve for a brake? mrod67 1994-2003 7.3L Power Stroke 4 02-21-2008 05:26 PM
2007 Diesel Power! Diesel Additive Dragt Racing Series DavidTD Drag Racing 0 08-23-2006 03:37 PM
White-Blue Smoke /warmup Rww 2003-2007 6.0L Power Stroke 11 04-06-2006 03:37 AM
