f250 8000# stock pull?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by carco21, this thread has received 7 replies and been viewed 1598 times.
post #1 of 8 (permalink) Old 07-24-2010, 11:43 PM Thread Starter
Have a friend pulling this Wed @ Clermont County, Ohio with 2009, F250, 6.4L Auto. He does have a power adder box but I do not know which one. He has never pulled this truck, and has to remove a little weight to get down to 8000#. What gear?? Hi or low side of transfer case?? He thinks High side because he has more engine than his old 6.0L, I say low side.
Tire pressures f and rear,?? w/stock tires.
Any other advice?? TIA.
carco21 is offline
post #2 of 8 (permalink) Old 07-27-2010, 12:52 AM
Low side T-case, hubs turned to manual lock.. Ease out in 1st shift 1-2-3 and hold on.. Front tires 25-30 lbs. backs 80 lbs.
I use a custom tune with torque converter locked.. 4250 rpm's
260" 1998 379/127 63" uni-bilt/ultracab W 1,040,000
1lw [email protected]/1850 In-framed at 850,000
Rtlo18b/3.42 46,000 Rockwells
2005 f-350 26 in Flat-top 4X4 DRW Lariat 6.0T/S ARP Studs,EGR Gone by RCD,SCTed by innovative, Dualed by MBRP,Tired by BFG
2004 f-250 CCSB Lariat 5.4 4x4
1985 F-250 4X4 6.9 all Fuel T-19
CowTruck is offline
post #3 of 8 (permalink) Old 07-27-2010, 01:48 AM Thread Starter
thanks CowTruck. 80psi rears?? I thought 50-60 rear and 40-45 fronts.
carco21 is offline
post #4 of 8 (permalink) Old 07-28-2010, 12:10 AM
Depends on your hitch height, blow them up for whatever the tire is rated for.. You know all that weight transfer to the back.. I haven't pulled my '05 yet but from what I've seen the coil sprung front likes to hop... I'm working on a way to tie the front axle to the frame (pre-load) to keep from hopping and help hold the front down..
CowTruck is offline
post #5 of 8 (permalink) Old 07-28-2010, 12:03 PM Thread Starter
CowTruck, I will lower the front suspension (torsion bars) down onto the rubber bump stops. I do not have extra support for GM's weak tie rod ends and sleeves so drop the suspension to better the angles of the steering linkage.
My hitch height is 22" and max allowed is 26", I am going to borrow one if possible to get closer to 26".
thanks.....................
carco21 is offline
post #6 of 8 (permalink) Old 07-29-2010, 07:57 AM
SSpeeDEMONSS's Avatar
torsion bars? i thought this was a ford? it helps if you run a strap from the frame to the front of the radius arm and crank it down. like said, run max psi on the rear and run the fronts lower. mid 20s-mid 30s is good. 4lo and locked hubs for sure.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #7 of 8 (permalink) Old 07-29-2010, 11:48 AM Thread Starter
SSpeed,,,,, Sorry I confused this with another post elsewhere,,,,, yes this is a Ford, was asking for a friend. He pulled last night and went 272' with a very light 40hp tune and completely stock otherwise.
My Duramax took third, 10 inches less than second @ 273'.
carco21 is offline
post #8 of 8 (permalink) Old 07-29-2010, 11:48 AM Thread Starter
Oh his Ford was the furthest pull for a Ford!!
carco21 is offline
2010 F250 Harley Davidson Stock Exhaust & Stock Lit Sidesteps blasteri Ford Parts 2 08-04-2010 11:18 AM
Down pipe for 8000 Ford with 7.8 JT's416cat Medium and Heavy Duty 8 11-14-2009 02:49 PM
1984 6.9 L International Harvester V8 IDI Diesel Engine (F250 Pull) do_lai Ford Parts 1 08-23-2009 07:36 AM
Trailering with Ford 8000 JT's416cat Medium and Heavy Duty 6 04-22-2008 12:59 AM
Pure stock pull vid from Ky Cummins Driver Sled Pulling 0 07-27-2007 09:59 PM
