rotary pump on my 1979 dt466 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skidly, this thread has received 0 replies and been viewed 2130 times.
post #1 of 1 (permalink) Old 05-09-2011, 12:47 PM Thread Starter
I have the rotary pump on my 1979 dt466 in a school bus. I had a fuel leak that ended up being the return line that goes to the steel line that returns to tank. Only thing open was a Napa and they made me a return line using hose with double steel braid, A tractor parts dealer here said that line will cause my pump to go bad because of fuel pulses. I found out he was talking about farm tractor engines that only had 1 return line that goes to filter. my engine has one on each side. 1 to filter, 1 to tank, Do you know if having this line for my return to tank can cause me pump failure ?
skidly is offline
dt466 rotary pump more power thebieri Medium and Heavy Duty 5 05-19-2010 08:07 PM
DT466 Timing with ROTARY pump Victor MD and HD - Modification Instructions, Product Installs and Tech Articles 8 02-13-2010 05:15 PM
rotary pump droolinforparts 5.9L Cummins 12 Valve (1994-1998.5) 5 11-04-2009 10:40 PM
rotary pumped DT466 nevrenufhp Medium and Heavy Duty 3 11-12-2006 01:36 PM
Stanadyne rotary pump Deezle1 Utility & Farm Tractors 3 10-02-2006 08:01 PM
