July 15th Frankfort, IN Truck pull. $9000 purse - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by aggar, this thread has received 0 replies and been viewed 1736 times.
post #1 of 1 (permalink) Old 07-09-2011, 09:37 PM Thread Starter
aggar's Avatar
LIke the title says $9000 prize money total Purse.
2.5, 2.6 and 3.0
Friday night the 15th of July starting at 6:30 pm
This is a pre-register event so let me know. Classes are filling up quick.
OK here's the rules and Payouts. IF you meet ITPA, COTPC or BOB rules thne you'll be ok but we will be teching trucks and if you don't meet the rules then you won't pull. Trucks in the money will be reteched after class.
$30 Hook fee non refundable if you don't meet tech.
Payouts are as follows
2.5 1st $1000, 2. $700, 3.$500 4.$300 5.$200 6.$150 7.$100 8.$50
2.6 & 3.0 1st $1200 2.$800 3.$500 4.$300 5.$200
Workstock/2.5 rules
Work Stock Class
True 2.5 Inducer Bore NO CLIPPED WHEELS / NO BUSHINGS/ NO TAPERED COVERS
.200 MAX mwe Groove
No Hanging Weights (Ballast Permitted)
8000lb Maximum (With Driver)
26 Hitch Height
DOT Tires
No Dual pumps, no compressed gases or Power Adders of Any Kind
Diesel Fuel Only
Traction bars are allowed
Valid Registration and Proof of Insurance Required
Single Wheel Trucks Must Run Single Rear Tires, Factory Dual Rear Trucks are Permitted to Run Dual Rear Wheels
‎2.6 Class Rules.
Hot Street
2.6 Inducer Bore
Minimum 1/8" Protrusion Into Bore
Compressor Blades Must Be Perpendicular to the Shaft
.200 MAX mwe Groove
Hanging Weights are permitted within 60 from axle CL
8000lb max (With Driver)
Driveshaft loops, u-joint shields and bump stops required
Dual pumps are permitted
No compressed gases of any kind
No Water/Meth
26 Hitch Height
DOT Tires
‎3.0 class rules
Super Street -
3.0 Inducer Bore
Compressor Blades Must be Perpendicular to the Shaft
.250 MAX mwe Groove
8000lb max (with driver)
Water Injection Permitted No methanol
26 Hitch Height
DOT Tires
Let me know if you're interested. Taking pre-register sign ups now.
2006 ccsb LBZ Not so stock
2001 ECLB LB7 Stock
aggar is offline
$10,000 Purse Aug 6th Sled Pull Rock Springs WY NADMmarketman NADM 1 04-28-2011 10:40 PM
Frankfort, IN July 16th Results aggar Sled Pulling 0 07-17-2009 03:42 PM
Frankfort,IN truck Pull July 16 aggar Sled Pulling 2 07-16-2009 02:43 AM
Truck Pull Mar 15th Sturgis, Ky Haloman Events and Gatherings 67 04-11-2008 02:18 AM
Truck Pull Mar 15th Sturgis, KY Haloman North Central 1 02-05-2008 03:22 PM
