weight will be on tomarro!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by alldiesels, this thread has received 11 replies and been viewed 945 times.
post #1 of 12 (permalink) Old 03-16-2006, 06:24 AM Thread Starter
Well guys cutting it last minute as usual, tomarro i will have my weight bracket and hitch done on my truck for the pull this weekend. I wanted something practival that didn't look like crap, so i went with a drawtit front mount hiden reciever hitch, off of that I am doing a piece of 2x2 sold stock, and will weld a piece of 6x6 tubing to it 20 inches long, i will be able to hold 10 JD suitcase weights so 1000lbs, say hello traction :} the thing i really like is 1 pin and it will only be adding 30lbs to the truck, doubt that will hurt my 1/4 times lol
robert
out
alldiesels is offline
post #2 of 12 (permalink) Old 03-16-2006, 08:37 AM
nice ive been wanting to build one for the front of my truck
fordguy is offline
post #3 of 12 (permalink) Old 03-16-2006, 12:15 PM
fuzzys69's Avatar
nice get some pics when its done
SOLD!!
2003 F-250 SC Shortbox
Singles Club #30
B.O.M.B. Squad #11
Ridin' Dirty Club #14
fuzzys69 is offline
post #4 of 12 (permalink) Old 03-16-2006, 12:22 PM
TDG MAFIA MEMBER #44
Send a message via AIM to 6point6 Send a message via MSN to 6point6
Yeah, I would like to see some pics posted up of that too!
2006 CC FX4 PSD 6.0 (GONE)
2005 LLY Duramax CC SB 4x4 - PPE Hot +2 ET on Level 8, MBRP 4" Straight piped Exhaust, PPE Intake, 315 Cooper STT's on stockers!
6point6 is offline
post #5 of 12 (permalink) Old 03-16-2006, 06:21 PM
Suck,Squish,Bang,Blow
StuckinMud's Avatar
Is the drawtite rated for 1k lbs of tongue weight? I've only seen them rated for 500lb. How does it mount and will the front of the frame take 1klbs. Move that weight 16"" of the front of the truck and it will actually weigh more at the reciever with leverage. The front of the frame is a crumple spot after all. keep in mind the heavier tongue weights for a rear hitch are based on how much weight is supported by the frame, this is also why the hitch goes so much farther into the truck wityh its mounting point. Also this is part of the reason every snow plow bracket has multiple mounting points on the front of the truck.
Not saying it wont work but make real sure that little hitch will take that load. you could end up using you 4x4 to get over the chunk of metal you drop instead of pulling that sled.
2004/04 F-350 6.0L(b.o.d. 12-11-03)
Just a couple of Mods :Thumbup:
More toys than time...
StuckinMud is offline
post #6 of 12 (permalink) Old 03-16-2006, 07:47 PM
fordt
How much does your truck weigh? I am curios as to how much weight you'll be able to hang.:
post #7 of 12 (permalink) Old 03-16-2006, 07:48 PM Thread Starter
Well i thought about that, but there rated to handel 500lbs all the time, not just once in a blue moon, also have you ever seen anything that isn't underrated?? my rear hitch is rated at 10k but what does a sled weigh? i think it is rated a 1k toung weight but i know what sled has to put over 5k of (toung weight), i do see where your coming from but i am not to overly worried about it.(and i am very anal about my truck just ask tadd lol)
robert
out
post #8 of 12 (permalink) Old 03-16-2006, 09:49 PM
They are "safe" weights.
Most things can handle 3X what they are rated for!
mikehalseyjr is offline
post #9 of 12 (permalink) Old 03-16-2006, 10:37 PM Thread Starter
well guys the hitch is all on, now all i need to do is finish welding up the bracket, here are pics of the hitch on the truck
https://www.thedieselgarage.com/galle...php?i=1149&c=9
just scrole through them
robert
out
post #10 of 12 (permalink) Old 03-17-2006, 01:25 AM
fuzzys69's Avatar
looks good
SOLD!!
Singles Club #30
B.O.M.B. Squad #11
fuzzys69 is offline
