Pulling tires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01 stroker, this thread has received 15 replies and been viewed 1463 times.
post #1 of 16 (permalink) Old 05-03-2006, 07:52 PM Thread Starter
Pulling tires
What do you guys think a good all around pulling tire would be. Most places I pull would be in red clay buy, I was just wondering what you guys have figured out
01 stroker is offline
post #2 of 16 (permalink) Old 05-03-2006, 08:10 PM
TDG Mafia - Booze Runner
Snowaholic's Avatar
BFG AT"s are what alot of the pullers use. I think Buntting uses them too, and did a lot of research on them
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
post #3 of 16 (permalink) Old 05-03-2006, 08:11 PM
Stick with an AT tire for sure, MT just break stuff. The tire of choice seems to be BFG AT's, but I'm thinking of trying some ProComp Xtreme AT's.
1996 F250, 219K miles, manual tranny. Beans Diesel Stage 1 injectors, 5 position chip, homemade intake, 5 in. straight pipe exhaust.
Strokerin is offline
post #4 of 16 (permalink) Old 05-03-2006, 08:24 PM
soot junkie
I have been pulling with BFG MTs for two years now but i will be trying a set of ATs in the next couple of weeks. The MTs offer too much traction on some of the tracks I go to.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #5 of 16 (permalink) Old 05-03-2006, 08:27 PM
Supporting Vendor
You see alot of tires w/ that kind of tread pattern w/ Clay tracks. Sled Puller used Mickey Thomspon Baja MTX Radial. Craig from enterprise uses the tire in the pic I think it's a Cooper. I used a Durango AT last year and paln to this year on the tighter tracks.
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #6 of 16 (permalink) Old 05-03-2006, 10:08 PM
moose99psd's Avatar
wow i had no clue that so much went into tires and dirt types....
moose99psd is offline
post #7 of 16 (permalink) Old 05-03-2006, 11:27 PM
Destroked
diesel dan's Avatar
BFG A/T's here too....:Thumbup:
diesel dan is offline
post #8 of 16 (permalink) Old 05-04-2006, 02:37 PM Thread Starter
Thanks for the info guys. What part of north carolina do you pull in smokin dually.
post #9 of 16 (permalink) Old 05-04-2006, 08:35 PM
soot junkie
Most of the tracks I go to are in the northern part of SC. I do go to one in East Bend, Statesville, and Oakboro NC.
post #10 of 16 (permalink) Old 05-05-2006, 12:59 AM Thread Starter
This is Will Barker and Nelson says HI to smokin dually. ITs good to finally know somebody else on here
