??'s on suspension blocks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by alldiesels, this thread has received 2 replies and been viewed 558 times.
post #1 of 3 (permalink) Old 06-02-2006, 04:12 AM Thread Starter
ok guys, before i finish these i just want to make sure you guys think they will work, what i am doing is running a bolt through the hole where the factory rubber stopper is mounted, and then will have a little plate welded on the bottem of the bolt, do you guys think this will be strong enough??
robert
out
alldiesels is offline
post #2 of 3 (permalink) Old 06-02-2006, 11:41 AM
BogginF350's Avatar
A buddy of mine has that set up, sorta... He uses 1 inch all thread the frame is plated where the nuts are welded and boxed. He can crank the all thread up and down to adjust for height.
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #3 of 3 (permalink) Old 06-06-2006, 04:21 AM
I was just wondering if you guys could give me some directions or advice on how you build these blocks? I'm going to my first pull on Saterday and would like to build the blocks before then...how do I do it?
RockinJW is offline
