slipper clutches - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Derag2, this thread has received 12 replies and been viewed 6135 times.
post #1 of 13 (permalink) Old 08-01-2006, 03:26 AM Thread Starter
Cummins
Send a message via MSN to Derag2
slipper clutches
Can anyone tell me in depth how a slipper clutch in a truck or tractor works????? Sounds to me like its a combo if a centrifical clutch and a regular clutch how i don't know...... All i really know for sure is there expensive
But me and my buddy have been trying to figure this stuff out, did some searching and didn't come up with much.....
2006 Dodge 2500 STL Cummins 6spd 4X4
Aries SS nerfbars taillightcover+3rd brake cover
5in SS Tip AFE Torque Tube Amsoil 4510 filter...
Smarty jr.
Derag2 is offline
post #2 of 13 (permalink) Old 08-01-2006, 07:34 PM
Gee Derag I thought somebody would surly know about slipper clutches. All these sled pullers an nobody noes anything about slipper clutches. I thought there would be a lot off replies to this. Where would you find out some info about this. 19 lookers an no replies. Come on guys help this guy out.
Diesel Guy is offline
post #3 of 13 (permalink) Old 08-01-2006, 07:49 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
Give it some time... He posted at 10:30 last night ( a lot of people are already out for the night) and now it is only 2:30 in the afternoon (a lot of people have a job and haven't gotten off yet) Just give it some time and I am sure some of our big pullers will help out... Only a few of the pullers have looked at it wait till some people like Brian or Robert, maybe they will know..
2003 F250 "Pulling Truck"
hhrecovery is offline
post #4 of 13 (permalink) Old 08-01-2006, 08:02 PM
2 plates and a floater piece in the middel the 2
House is offline
post #5 of 13 (permalink) Old 08-01-2006, 08:23 PM
Can you explain on how it works?
post #6 of 13 (permalink) Old 08-01-2006, 09:40 PM
It works like a standard clutch. Flywheel, then first clutch disc, then floater plate, then second clutch disc, then pressure plate. The dual disc allows the heat and friction material to be spread out over twice the area as a standard single disc. There are no dampening springs in the clutch discs, this allows you to ride the clutch for a longer period of time without damaging or overheating the discs. Most dual disc clutches use ceramic friction buttons with a steel backplate to help dissapate heat and prevent warping. Hope this helps a little.
imported_Smokem is offline
post #7 of 13 (permalink) Old 08-01-2006, 09:52 PM
Here are some pictures that may help.
Standard pulling clutch disc http://www.haisleymachine.com/Clutch...0MIBA%20SM.jpg
Machined flywheel for floater http://www.powerpartsengineering.com.../clutch008.jpg
Floater plate http://www.haisleymachine.com/Clutch...s/MVC-020F.JPG
Clutch disc sitting in machined flywheel http://www.powerpartsengineering.com.../clutch005.jpg
Everything for a triple disc http://www.powerpartsengineering.com...cclutch004.jpg
post #8 of 13 (permalink) Old 08-01-2006, 09:52 PM
To Add To What Smokem Said. The Clutch Uses A Set Of Counterwieghts On A Cam System. As Engine Rpm Increases The Flywheel Spins The Wieghts Out Using Cintrifical Force Appling Preasure To The Cam And Then To The Preasure Plates. The Faster The Rpm The Harder The Clamping Force.
TUSTUD is offline
post #9 of 13 (permalink) Old 08-01-2006, 09:57 PM
Your describing a weighted clutch, something like a Crower. Most trucks use non-weighted dual discs. I believe Chris Watson used to run a Crower in his old blue truck. Weighted clutches are most commonly used in tractors.
post #10 of 13 (permalink) Old 08-01-2006, 10:48 PM
I Run An Auto And The Only Slippers I Have Delt With Are Ag Clutches And One From Zoom. So Thanks For The Corection. So What Do They Use To Ingauge The Clutch. Or Are They Just Manuely Slipping It.
TUSTUD is offline
