first pull this weekend - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 05dury, this thread has received 7 replies and been viewed 695 times.
post #1 of 8 (permalink) Old 08-03-2006, 07:23 PM Thread Starter
formally dodge97ctd-sc member #12
05dury's Avatar
Send a message via Yahoo to 05dury
hey ya'll im coming up on my first pull this saturday and i drive a well its in my sig...but the question is,..is everyone says i should pulll in 3rd gear in 4L....is that correct??
-bubba-
2005 chevy 2500 lly duramax extended cab shortbed 4x4...got some go fast stuff done to it
05dury is offline
post #2 of 8 (permalink) Old 08-03-2006, 08:23 PM
You pullin' down there or headed somewhere else? A lot of guys that I have read about don't seem to think stock or near stock trucks could get off the line with 3rd. They said 2nd would be better. Then again I just pull a gasser with an auto so I may not be the best help. Good luck.
CBSuperduty is offline
post #3 of 8 (permalink) Old 08-03-2006, 08:45 PM
3rd 4low may work for you. Try it and if it doesn't feel right shut it down in the designated area, go back and try a different gear. I would suggest 2nd 4low with a stock clutch, if you are just trying to get your first pull under your belt. You won't go very fast but you have a lot better chance of keeping your stock clutch intact.
I could show you what some power and 3rd 4low does to a stock clutch. The truck doesn't smell very good on the way home either.
94 Dodge reg cab 2wd auto
97crewcab is offline
post #4 of 8 (permalink) Old 08-04-2006, 12:09 AM
Diesel Fume Inhaler
If you don't like to see a stock clutch white smoking and no tire movement at all, then I would pull in low 2nd. You can almost bet that your going to be really hard on the clutch with a 3rd gear pull.
'01.5 2500 4x4 Quad Cab 5spd Edge Comp Drag, Extrude Hone Injectors , Haisley's connector tubes & standpipe, O-ringed & studed, Custom A1000 fuel system, ATS manifold, 5" exhaust 6" tip, Proguard 7 race edition, HT 64mm, and EEP's pulling clutch with 1 3/8" input
cowboyup20x is offline
post #5 of 8 (permalink) Old 08-04-2006, 12:52 AM Thread Starter
05dury's Avatar
alright 2nd in 4Low gotcha guys thanks for the help....the pull is in McLouth,Kansas if any of ya'll wanna try and make it cuz im trying to get all the diesel trucks i can get....
-bubba-
05dury is offline
post #6 of 8 (permalink) Old 08-04-2006, 02:13 AM Thread Starter
05dury's Avatar
another question...i dont wanna sound worried but is there a good chance of me breaking something or not???
-bubba-
05dury is offline
post #7 of 8 (permalink) Old 08-04-2006, 02:20 AM
Destroked
diesel dan's Avatar
There is always chances of breakage....if it does, get out, smile and build it stronger.
diesel dan is offline
post #8 of 8 (permalink) Old 08-04-2006, 03:28 AM Thread Starter
05dury's Avatar
true to that...and if i do break id love to see the look on my partents faces when they hear i broke something.
-bubba-
05dury is offline
