Woodbine IA pull Aug 26 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cowboyup20x, this thread has received 19 replies and been viewed 1346 times.
post #1 of 20 (permalink) Old 08-19-2006, 04:47 AM Thread Starter
Diesel Fume Inhaler
Who is going to the pull in Woodbine IA on the 26th??
'01.5 2500 4x4 Quad Cab 5spd Edge Comp Drag, Extrude Hone Injectors , Haisley's connector tubes & standpipe, O-ringed & studed, Custom A1000 fuel system, ATS manifold, 5" exhaust 6" tip, Proguard 7 race edition, HT 64mm, and EEP's pulling clutch with 1 3/8" input
cowboyup20x is offline
post #2 of 20 (permalink) Old 08-19-2006, 09:49 AM
How many trucks will be pulling in Woodbine?. I might go. What classes.
Diesel Guy is offline
post #3 of 20 (permalink) Old 08-19-2006, 03:06 PM
What kind of rules, weight, etc?
94 Dodge reg cab 2wd auto
97crewcab is offline
post #4 of 20 (permalink) Old 08-19-2006, 03:52 PM
If we come up with a manual and change it over by then we probably will. Heck we may even if we don't too.. Will keep you posted.
CBSuperduty is offline
post #5 of 20 (permalink) Old 08-23-2006, 04:17 AM Thread Starter
Diesel Fume Inhaler
Sorry for the wait, I was waiting for the sled owner to call me back.
The sled is "Fear This" from the Woodbine area.
The pull is on the 26th in Woodbine IA @ noon. The actual pull probably won't start until 1pm, but get there around noon so you have time to weigh in.
There will be gas and diesel trucks. Tractors are pulling the next day.
Diesel classes will have a 7800 lb, 8600lb, and open class.
Only real regulations are going to be hitch height no higher than 26", and no nitrous/propane.
You can run a blocked suspension, weights to make class limitations, water injection, exhaust exiting in any location, and dual tires if you have a dually.
These are diesel street classes, so you should probably have DOT tires, no cut tires. We will allow trucks without plates like the power pullers from NE, gotta play nice.
I hope to be bringing my truck plus 4 to 7 others if all goes well. This is hopefully going to be a fun event where everyone can relax and bs a little. The more the merrier!!
Pull usually doesn't last more than 4 hours give or take.
post #6 of 20 (permalink) Old 08-23-2006, 04:23 AM Thread Starter
Diesel Fume Inhaler
Some of the gang that might show.
post #7 of 20 (permalink) Old 08-23-2006, 11:44 AM
No Fords that sucks. Im not coming. J/K. Looks like a great pull coming up an the rules most people can live by. Will see what the schedule holds. 4 hr pull sounds like a pretty good number off trucks will pull. Have they had truck pulls in Woodbine in previous years? Good Luck. Seeing your truck pull in Arlington you should do well. BTW how did you place there?
post #8 of 20 (permalink) Old 08-23-2006, 02:11 PM
Well guys I won't be pulling at this event as we are pulling the TC out of YESDEERE... tonight to send back and have reworked. I may have to watch the boys that morning as moma has something to do. I may still head up there to watch and talk to you guys more.
Chris
post #9 of 20 (permalink) Old 08-23-2006, 10:55 PM
1st of course, 2nd was the silver Duramax 12ft short.
imported_Smokem is offline
post #10 of 20 (permalink) Old 08-24-2006, 01:35 AM Thread Starter
Diesel Fume Inhaler
The ford guys didn't show up this weekend, there should be atleast three that are coming to pull that I know of, maybe more.
Yes they have, just not advertised enough.
