Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HighTQCummins, this thread has received 6 replies and been viewed 672 times.
post #1 of 7 (permalink) Old 08-28-2006, 02:50 AM Thread Starter
Mafia #42
HighTQCummins's Avatar
Location: Valley Forge PA/West Long Branch NJ (college)
Send a message via AIM to HighTQCummins
Question
I have noticed this in alot of videos on this website. When trucks are building boost, as the RPM's come up it seems to sputter up to redline, then the turbo spools up. What is this? What is the reason behind it? Input would be greatly appreciated.
Hank
TDG and the Mafia lives on
TDG B.O.M.B. Squad #5
My Truck:2007 Toyota Tacoma V6 4x4
Diesel is in my blood, I guess you can call it a disease, sadly there is no cure for it, it's my cross I must carry
HighTQCummins is offline
post #2 of 7 (permalink) Old 08-28-2006, 03:00 AM
fordt
Because they are Cummins :
I am not positive, but 99% sure it's because of so much fuel, and little boost. Once the boost comes on, the fuel comes in, all is good.
post #3 of 7 (permalink) Old 08-28-2006, 03:00 AM
diesel_ram_man's Avatar
Images: 6
correct me if i'm wrong but i think it is turbo lag, mostly sled pullers with really big single turbos.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #4 of 7 (permalink) Old 08-28-2006, 03:16 AM
Diesel Fume Inhaler
Really big fuel lines will cause this to happen.
'01.5 2500 4x4 Quad Cab 5spd Edge Comp Drag, Extrude Hone Injectors , Haisley's connector tubes & standpipe, O-ringed & studed, Custom A1000 fuel system, ATS manifold, 5" exhaust 6" tip, Proguard 7 race edition, HT 64mm, and EEP's pulling clutch with 1 3/8" input
cowboyup20x is offline
post #5 of 7 (permalink) Old 08-28-2006, 03:21 AM
Images: 6
I was off a little, but basicly alot of fuel going in the engine at once.
Can You Keep Up??
post #6 of 7 (permalink) Old 08-28-2006, 04:37 AM
Actually it's lack of pressure at low RPM.
imported_Smokem is offline
post #7 of 7 (permalink) Old 08-28-2006, 03:35 PM Thread Starter
Mafia #42
so its basically like putting too much wood on a fire, it can burn it until it has enough heat and air?
Hank
