clutch tech - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by buckeyestroker, this thread has received 27 replies and been viewed 2004 times.
post #1 of 28 (permalink) Old 12-30-2006, 03:08 AM Thread Starter
clutch tech
alright guys help me out. i just got a 94 12 valve with a handshaker. i plan on doing some improvements and start playing at the local levels. im going to need a clutch. i plan on 400 to 500 hp proably closer to 400 w/o the water. i have a line on a south bend mu13-125 con ofe for 500 bucks slightly used (it is a 900 clutch from sb). it will support 400 hp according to sb. am i wasting my time and money by installing this clutch. say at 400 hp how many hooks am i going to get.
or should i just get the 2 plate and be done?:squish
buckeyestroker is offline
post #2 of 28 (permalink) Old 12-30-2006, 03:12 AM
diesel_ram_man's Avatar
Images: 6
Well I see you posted this in the Sled pulling section, does that mean you plan on doing sled pulling? If so, if you plan on doing any sled pulling you better just go ahead and get the Dual Disk clutch.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #3 of 28 (permalink) Old 12-30-2006, 03:14 AM
If your going to sledpull at all your going to need a dual disk PERIOD.
SlowDiesel is offline
post #4 of 28 (permalink) Old 12-30-2006, 03:57 AM
Bouncer
: :iagree
post #5 of 28 (permalink) Old 12-30-2006, 04:56 AM
01duramax6spd's Avatar
Dual Disc all the way!
01duramax6spd is offline
post #6 of 28 (permalink) Old 12-30-2006, 03:24 PM Thread Starter
:thanks: :thanks: NUFF SAID THANX:thanks:
OK LETS HERE IT WHAT KIND. ALL I HERE ABOUT IS SOUTH BEND...THEY HAVE A FEW 2 PLATE SET UPS.
IS SOUTH BEND THE ONE TO GET??? AND WHICH ONE ?
UPDATE THE INPUT SHAFT NECESSARY?
ALSO IS IT WISE TO RUN A BLANKET WITH A 2 DISC
I WANT TO KEEP MY FEET AND OR LEGS.
post #7 of 28 (permalink) Old 12-30-2006, 04:43 PM
Bouncer
South Bend is the only clutch IMO. Call Peter and have a talk with him and tell him what you want to do. He will not sell you somthing you don't need or something that won't work for you.
post #8 of 28 (permalink) Old 12-30-2006, 04:52 PM
I'm getting a dual disk in feb. After talking with the guys at SB there was only one choice.
mckey73 is offline
post #9 of 28 (permalink) Old 12-30-2006, 10:01 PM
Ive had good luck with haisleys dual discs
House is offline
post #10 of 28 (permalink) Old 12-31-2006, 01:35 AM Thread Starter
house is haisely's cheaper?
i mean south bend clutch's cost a azz load:splat
i will have more in the clutch than all the upgrades for the motor.
