kill switch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lubeowner, this thread has received 2 replies and been viewed 879 times.
post #1 of 3 (permalink) Old 01-30-2007, 03:34 AM Thread Starter
lubeowner's Avatar
kill switch
Any one out there that is into pulling have any thoughts on how to wire a kill sawitch to the back of the truck. According to our club rules it does not need to be a air cutoff only a kill switch in case of a truck coming unhooked.
lubeowner is offline
post #2 of 3 (permalink) Old 02-01-2007, 03:12 AM
pontiacross's Avatar
I have never messed with one but I think all that you would do is run your ignition wire to the back and open it with a your kill switch. I think some jet skiis are set up with a switch that you tie a string to your life jacket and when you fall off it pulls out the swith and kills the engine. maybe you can use one of those switched on your truck.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 3 (permalink) Old 02-01-2007, 03:40 AM
on a truck with ecm i have it ran to the ecm fuse in the fuse block and re fuse it inline with kill switch wires to back of the truck to a Personal water craft togglee switch with a small cable and ring
House is offline
