this form is awsome / what gear should I pull in - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Kleiner, this thread has received 6 replies and been viewed 852 times.
post #1 of 7 (permalink) Old 02-05-2007, 09:36 PM Thread Starter
i have a 06 3500 drw ram, it has bulldog w/crazy larry, boost fooler, 5" exhaust, duel fass pumps, cold air, all new performance trans, water meth, iv'e several different things, just cam out of a gas motor pulling truck, it was 1st gear and 4 lo, yes i wised up and traded it for a diesel, also thinking about nitrous
Kleiner is offline
post #2 of 7 (permalink) Old 02-06-2007, 01:59 AM
depends on your truck, clutch type double disc for sure, how many hooks you want out of your clutch higher gear usually means more heat (slipping) , how heavy the sled is, some farm shows and local pulls the sled is prety light and county fairs w/ big pocket pusues bring the big boys and big weight and drop pan, type of surface loose, tight, dry, wet, truck set up (any movement other than forward takes power away like hopping even as little as rear end squating) equals les time to get on top of turbo and most importantly the driver skills.
At any rate nuff jabber i use 3rd low and 4 low mostly i used hi 1 once on a real sloppy mud basically with light sled most guys were taking it 300 plus with floating finish. i try to get off the clutch in 3 seconds or less. i hope this helps
J
buckeyestroker is offline
post #3 of 7 (permalink) Old 02-06-2007, 02:27 AM
BogginF350's Avatar
J
He is running a auto tranny.
I think most auto guys in a dodge run 1st and second low range.
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #4 of 7 (permalink) Old 02-06-2007, 04:41 AM
ok never mind me my bad:splat
post #5 of 7 (permalink) Old 02-06-2007, 01:45 PM Thread Starter
yes it is a auto, w/ triple disc converter, so you are thinking 4 low and second gear
Kleiner is offline
post #6 of 7 (permalink) Old 02-08-2007, 02:03 AM
Tire size comes into play, the high the better. Stick: start in the highest gear you can. Auto: shift till you drag the motor down. There is a DuraMax that pulls with us that shifts 3 times.
97 club cab 8 ft box, 4x4, 10 speed 100 plate, BHAF, gauges, timing @15, water injection (devils own), 4 inch exhaust 5 inch stack, double disk, 33" BFGs, Detroit Tru Trac, HTT 35Hx, 4k gov, 60 lb springs pin tabbed, ATS exhaust manifold, high flow delivery valves, fire rings and studs, no fan (two 16" electircs)
mega-ram is offline
post #7 of 7 (permalink) Old 03-08-2007, 10:38 PM
Most guys around here with autos let the tranny shift for them. It nows when to shift don't worry about it and concentrate on the truck and the track.
BlueOvalDiesel is offline
