Reg. cab vs. Ext cab - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by R4farms, this thread has received 21 replies and been viewed 1480 times.
post #1 of 22 (permalink) Old 02-21-2007, 08:40 PM Thread Starter
I bleed John Deere green
I have been to quiet a few pulls now, and Im wanting to get into it. Whats about the gross wt. for a ext. cab long bed Dodger? Whats the most common weight classes at most local pulls? Cause I dont want a dually!! And DONT want to pull against em'! :
05 LLY Dirtymax, NOT STOCK FOR LONG!
SOLD 98 Peckerbilt 379 Kitty CAT 410 pullin a 53' Wilson SilverStar livestock
95 INTL 9400 N14 Cummins pullin a 39' Wilson PaceSetter grain hopper
R4farms is offline
post #2 of 22 (permalink) Old 02-22-2007, 01:18 AM
i hate to tell yeah but the only diesel classes run a 8,000 pound class and a few 10,000 pound classes and yes you will have to pull against dually. You will get along fine against a dually as long as you have the torque and the right setup on your truck
MOOSE 04 is offline
post #3 of 22 (permalink) Old 02-22-2007, 05:55 PM
Local pulls around here dont allow duallys or pull one tire on each side, 8000 or 8500 around here. Not worth it imo. Too many boys w/toys. So many guys are pullin g in stock classes w/chips and nitrous propane etc etc (hiding bottles under center consoles etc etc etc its all about the boy w/the most money, thats why I quit pulling trucks, stick to tractors. Still a few boys out there w/big bucks bending the rules but not as many.
#23 Singles Club
thejdman04 is offline
post #4 of 22 (permalink) Old 02-22-2007, 05:59 PM
Generally longer is better for weight transfer, (dont have to put as much weight on the front end to keep it down), so you arent using up all your weight hanging off the front to keep the nose down. Its harder to pick the front up on a longer truck. A longer truck weighs more, but the leverage they give you exceeds the weight they use up.
#23 Singles Club
post #5 of 22 (permalink) Old 02-22-2007, 07:47 PM
your in Indiana 90% of the pulls are 8000lb and all cab and wheel configuartions run in one class. theres a few 7500 srw only pulls but not many
House is offline
post #6 of 22 (permalink) Old 02-22-2007, 09:15 PM
If your truck is set up right, dual wheel P/U's wont matter.
maxxis_mudder is offline
post #7 of 22 (permalink) Old 02-22-2007, 09:27 PM
Smile Dually's no problem
Read my sig, the truck weights about 7200 by itself. I add about 600 lbs and then me and a full tank of fuel. Usually the longer wheel base is an advantage, front does not lift as much. Pulls in this area are 8000 lb class but duallys pull in, and if heavy have to hook lower.:smoke
97 club cab 8 ft box, 4x4, 10 speed 100 plate, BHAF, gauges, timing @15, water injection (devils own), 4 inch exhaust 5 inch stack, double disk, 33" BFGs, Detroit Tru Trac, HTT 35Hx, 4k gov, 60 lb springs pin tabbed, ATS exhaust manifold, high flow delivery valves, fire rings and studs, no fan (two 16" electircs)
mega-ram is offline
post #8 of 22 (permalink) Old 02-23-2007, 02:26 AM
it is all about setup
MOOSE 04 is offline
post #9 of 22 (permalink) Old 02-23-2007, 03:25 AM
mrector's Avatar
8000 and 8400 are the regulars around where I pull. I have to pull with the duallys(8400), but like ^^^^^said before...set up is key.
My 97 cab ,with me in it, weighs in at 6500(me=190), so I can add 1500-1900 lbs WHEREVER I want. I usually hang about 1000 off the front, and whatever I can in the bed, near the cab. I do not know how much a ex cab long bed weighs, but I'd say about 600 more than mine, give or take.
I have noticed too, that in a street truck configuration, the long wheelbase trucks tend to "hop" more than a regular cab. Pending more drivetrain failures, due to the "hopping".
Mikey
89 w250 project truck
mrector is offline
post #10 of 22 (permalink) Old 02-24-2007, 08:36 PM
Why you afraid of duallies? I have beat plenty of them and plenty of them have beaten me.
Its all about your setup like posted above.
Although, long wheel base trucks rule the roost.
SlowDiesel is offline
