and bump stops - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6L strokin, this thread has received 5 replies and been viewed 2015 times.
post #1 of 6 (permalink) Old 12-23-2008, 06:27 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
and bump stops
anything else belong in the pulling section?
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #2 of 6 (permalink) Old 12-24-2008, 12:38 AM
pontiacross's Avatar
mine are pretty simple they just slide over and clamp to the origional bump stops.
I am going to make some better ones this winter but this got me through 2 seasons and I spent all of about 20min. makeing them.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 6 (permalink) Old 12-24-2008, 02:51 AM
fuzzys69's Avatar
i run timbrens as my bump stop, and its good for towing too.
SOLD!!
2003 F-250 SC Shortbox
Singles Club #30
B.O.M.B. Squad #11
Ridin' Dirty Club #14
fuzzys69 is offline
post #4 of 6 (permalink) Old 12-24-2008, 04:27 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
I used a piece of 4"x4" 1/4" thick square tubing. I built a bracket and attatched it to my frame. I drilled holes in the blocks and the top brackets. All I have to do is jack the rear bumper up a little, slide in the blocks, bolt them and it is ready to go. The block itself fits right in between my axle u-bolts so the blocks can't go anywhere.
Putco light bar
Dieselwrencher is offline
post #5 of 6 (permalink) Old 12-26-2008, 06:33 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
that is a cool idea! never seen ne like that before...i dont have ne pics of mine on the comp but i will take a few..
Previous Rides:
post #6 of 6 (permalink) Old 12-31-2008, 02:23 PM
Truck pullin' S.O.B.
OffKilter's Avatar
Images: 13
I used some 3" rectangular steel and 4 " rectangular steel and I bolt them to the brackets for the over load springs so that they push down on them at emty ride height. You can't have blocked rears in the Pure Stock classes around here and this set up works really well it just sucks driving with them in.
1999 F-250 Lariat, Red, Super Cab, Short Box, 6.8L V-10
2003 F-350 XLT Regular Cab Long Box 6.0L 6-speed, tinted windows, push bar, 4inch MBRP exhaust, Edge Juice w/ attatude.
1969 F350 "The Shillelagh" future pulling truck, 428ci, 4-speed, 4:10 gears.
OffKilter is offline
