Pulling Turbo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by '05Supersmoker, this thread has received 16 replies and been viewed 1171 times.
post #1 of 17 (permalink) Old 04-04-2007, 12:28 AM Thread Starter
Pulling Turbo
I need help selecting a turbo for my pulling truck. It is a '91 P-Pumped, 330 injectors, oversize fuel lines, laser cut dv's, 4k springs, auto tranny, etc. I have a brand new ht3b sitting in my shop right now. i am pretty sure it is a triple entry. Does any know if i would be able to spool that big turbo or i am i just pissing in the wind?
'05Supersmoker is offline
post #2 of 17 (permalink) Old 04-04-2007, 12:44 AM
diesel_ram_man's Avatar
Images: 6
It would take a ton of fuel to spool it, but it is possible. Whats the inducer and exducer size of your HT3B? I know a few guys running a GT42 as a single, and it doesn't lite until 2100RPM w/ a ton of fuel (upwards of 650cc's)
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #3 of 17 (permalink) Old 04-04-2007, 01:07 AM Thread Starter
I am really not sure of the inducer size. I have plenty of fuel going to it. the guy that built the pump says its around 800 but it has not been on a flow bench.
post #4 of 17 (permalink) Old 04-04-2007, 01:24 AM
Images: 6
Well if that is true it should spool it relativity quickly. Depending on exact size of turbo.
Can You Keep Up??
post #5 of 17 (permalink) Old 04-04-2007, 03:42 PM
You should be able to spool it without much issue. If I remember right, the HT3B is on the small side for a big pulling turbo anyway. It makes a nice one for a set of street twins though.
1996 F250, 219K miles, manual tranny. Beans Diesel Stage 1 injectors, 5 position chip, homemade intake, 5 in. straight pipe exhaust.
Strokerin is offline
post #6 of 17 (permalink) Old 04-09-2007, 04:19 AM
You will never spool an ht3b I know a guy that tried it on a 97 with some serious fuel and didnt come close to spooling it.
SmokingDodge is offline
post #7 of 17 (permalink) Old 04-09-2007, 04:34 AM
AKA slowdog racing
Send a message via Yahoo to maddogg1019
just run a smaller one in front of it then you wont have to guess about spooling that big turbo.
-Curtis-
2006 chevy 2500 LBZ ec sb AKA Blue Blur :chevy-EFI live from mcrat and a few slowdog racing tunes, AFE stage 2 with PG 7, MBRP 5" turbo back,Bilstein shocks, Autometer cobalt pyro and boost, BD fullbore manifold, SD manifold, 2" block in the rear, caltracs traction bars, and 33 x 12.5 r 16.5 sport kings. 2 10" memphis subs, 1050 max watt lightning audio amp, alpine head unit.
[email protected] mph with whats above.thanks pat and kat.
coming soon - suncoast V trans., slowdog duel pumps
"Its a matter of horsepower for eight seconds or miles an hour that's the way i am and it's a fact i cant ignore yeah big four-legged, fuel-injected runnin' wild or radar-detected a man can always stand a little bit more horsepower."-Horsepower-Chris LeDoux
Me kickin azz
My truck and other things
Myspace
maddogg1019 is offline
post #8 of 17 (permalink) Old 04-09-2007, 08:42 AM
Depends on what exhaust sizing you have on the H3TB. I think you can get a 19 housing for it. That would sure help.
post #9 of 17 (permalink) Old 04-12-2007, 12:46 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
I know a guy who had a 1000hp plus 12v cummins with a S300 off of a John Deere tractor on it and it spooled fine but it usually lit around 2800. This truck had one turbo and water/meth injection to cool the charge air. And this puller was a 2wd. The only time he got beat was when the truck broke, as far as I can remember.
Putco light bar
Dieselwrencher is offline
post #10 of 17 (permalink) Old 04-12-2007, 03:41 AM Thread Starter
Thanks for the input. i know it is a big turbo and i would have to make quite a few modifications to it to make it fit. i guess i should just go with the sled puller 66
