Pull in NC - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokin dually, this thread has received 11 replies and been viewed 1089 times.
post #1 of 12 (permalink) Old 05-05-2007, 03:37 AM Thread Starter
soot junkie
Pull in NC
This is the same pull that is posted in the Carolina PSD section, but I just wanted to make sure that everyone sees it. The pull is in Oakboro, NC on May 12. It starts at 1:00pm I think. We would like to get as many trucks there as possible. If you would like more info let me know.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #2 of 12 (permalink) Old 05-05-2007, 04:10 AM
where is oakboro, nc?
cumminspower_va is offline
post #3 of 12 (permalink) Old 05-05-2007, 04:36 AM
does anyone know where oakboro, nc is? if so, let me know.
thanks
cumminspower_va
post #4 of 12 (permalink) Old 05-05-2007, 01:31 PM
mrector's Avatar
Near charlotte NC, you can just follow us down........
Mikey
89 w250 project truck
mrector is offline
post #5 of 12 (permalink) Old 05-05-2007, 02:35 PM
Smokin 5.9's Avatar
I wish it would have worked out not having two on the same day already.
:smoke
00' Ext. Cab short bed, 5 Speed, AFE, 4" two 5" Miters, Injectors, HRVP44, .93 lines&tubes, Edge Drag, Redline, Autometer Gauges, Southbend DD Clutch, Garrett Turbo w/ Manifold, BD Hose and Clamp Kit, Head Fireringed, Port and Polished, Upgraded Valve Springs, A-1 Head Studs, Haisley Street Grind Cam, Fluidampr, Water/Meth, PSI Fuel System, BD Short Shifter, BD Cool Down Timer, 2" leveling blocks, Voodoo Trac Bars, Road Armor front bumper painted to match, 305/70/16 BFG TA's on 16x10 D C's
97 12v Reg. cab, Auto. AFE, 0 plate, Cut DV's, 4GSK, 4" straight, 16.5*, autometer gauges, billet georend.
Smokin 5.9 is offline
post #6 of 12 (permalink) Old 05-05-2007, 03:03 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
Isn't the ones down in Abingdon starting on the 12th also???
2003 F250 "Pulling Truck"
hhrecovery is offline
post #7 of 12 (permalink) Old 05-05-2007, 03:34 PM
FRANKEN STROKE
Tea the Abingdon pull is also on the 12th! But well support the Oakboro pull too! Ill try to get directions to both posted!
96 F-250 4X4,DP Tunner, EZmod, up graded IDM, custom drive shafts, staight axle up grade, 5-speed,head studs, bps bypass, dual HPOP's, AFE Filter, aeromotive fuel system, tubes, springs, oringed, copper head gaskets, 5" stacks (all chrome), south-bend dd clutch, H2E big spinny thing, some hugh-jazz injectors, 3" body lift (had to fit the turbo in), homemade traction bars fromt and rear, blood sweat & lockers!!
Four different trucks had to die to make this one!!!!!!!!!!!Thats why we call him FRANKEN STROKE! Too much fuel, and not enough money
Sled pulling in NC,TENN,VA,and anywere else theyll let us!!!!!
P.S. Dont be afraid of the sawzall! It can fix anything!
[email protected]
DONATIONS EXCEPTED!!!!!!
Franken-stroke is offline
post #8 of 12 (permalink) Old 05-06-2007, 04:06 PM Thread Starter
soot junkie
From Va, the best I can tell you is to take I77 south to I85 south. Then take I485 towards Pinevile. Turn on the the 24-27 exit. Turn left on 24-27. Go through Locust to Red Cross. There is a small sign on the side of the road that says Red Cross. Once you get here there will be banners up that say Big Lick Truck and Tractor pull. Take a right on Hwy 205. The pull will be on the right about 1 to 1.5 miles down. You will see more banners.
post #9 of 12 (permalink) Old 04-11-2008, 05:18 PM
O2CUMMINS's Avatar
Send a message via Yahoo to O2CUMMINS
Those directions are pretty good. It is apprx 20 min from albemarle nc and if you get on hwy 52 in albemarle it will knock off a little time.
2002 Cummins 24v 6speed Grandrock 6" Aussies, : ADRENALINE , BHAF with k&n intake tube, Autometer pyro, boost & Fuel pressure gauge, 100 HP sticks, FASS, new injection pump. Valair DD and 62/65/12 charger.
:smoke
O2CUMMINS is offline
post #10 of 12 (permalink) Old 04-15-2008, 01:19 AM
Anyone have an address so I can put it into the GPS:shrug:
Tony, 1994 F250 XLT ext. cab, long bed, 7.3 IDI Factory Turbo, 4x4 manual hubs, E4OD, 4:10 gears, K&N air filter, PSD oil filter, TruxPort tonneau cover, 176,000 miles and counting.
fuzzy1626 is offline
