Next pull in Oakboro - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokin dually, this thread has received 3 replies and been viewed 489 times.
post #1 of 4 (permalink) Old 05-31-2007, 01:30 AM Thread Starter
soot junkie
The next pull in Oakboro NC will be on June 23. It will start at 1pm. Good pull last time, so come out and try your luck.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #2 of 4 (permalink) Old 06-19-2007, 02:55 AM Thread Starter
soot junkie
Pull is still on for this Saturday. It will start at 1pm.
post #3 of 4 (permalink) Old 06-19-2007, 06:47 PM
Smokin 5.9's Avatar
A couple of us are planning on coming down Saturday. :Thumbup:
:smoke
00' Ext. Cab short bed, 5 Speed, AFE, 4" two 5" Miters, Injectors, HRVP44, .93 lines&tubes, Edge Drag, Redline, Autometer Gauges, Southbend DD Clutch, Garrett Turbo w/ Manifold, BD Hose and Clamp Kit, Head Fireringed, Port and Polished, Upgraded Valve Springs, A-1 Head Studs, Haisley Street Grind Cam, Fluidampr, Water/Meth, PSI Fuel System, BD Short Shifter, BD Cool Down Timer, 2" leveling blocks, Voodoo Trac Bars, Road Armor front bumper painted to match, 305/70/16 BFG TA's on 16x10 D C's
97 12v Reg. cab, Auto. AFE, 0 plate, Cut DV's, 4GSK, 4" straight, 16.5*, autometer gauges, billet georend.
Smokin 5.9 is offline
post #4 of 4 (permalink) Old 06-20-2007, 12:00 AM
mrector's Avatar
I'll ride down w/smokin'5.9 and help you guys carry weights.
89 w250 project truck
mrector is offline
