Last years pulling vid - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ben46a, this thread has received 11 replies and been viewed 1041 times.
post #1 of 12 (permalink) Old 06-20-2007, 06:39 PM Thread Starter
Heres a vid of my truck pulling in antigonish last year. Kinda rough of the line but im still figuring out how to launch the stick truck.
http://www.youtube.com/watch?v=xiK2sevhmvA
2005 GMC 2500HD 4x4 DMax ZF-6
Blizzard 800 plow, Triple stack of doom
285 BFG mud terrains, Conrad 4" straight pipe, Dynadroit dual disc
Its a work truck
Ben46a is offline
post #2 of 12 (permalink) Old 06-21-2007, 03:22 AM
wow you are lucky you didn't break. what kind of clutch are you using and how hard are you trying to launch it.
MOOSE 04 is offline
post #3 of 12 (permalink) Old 06-21-2007, 01:47 PM Thread Starter
Using a south bend DD ceramic. Wqasnt trying to launch hard, but the track was tighter than anticipated so i had my 285's on. I had to launch hard to get it moving without stalling.
Its a work truck
Ben46a is offline
post #4 of 12 (permalink) Old 06-23-2007, 02:28 AM
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
I would say to just run your RPM's up to the governor, and slowly let off the clutch until you get anywhere from 10 to 20lbs of boost and then drop it. That way I don't think you will bounce any, and probably will pull a little farther, because you are losing traction every time you bounce. Just my :2cents
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
post #5 of 12 (permalink) Old 06-24-2007, 05:35 PM
stillcrazyinlaw's Avatar
Images: 3
maybe walk it out 5-10 ft. before flooring it. that way you get it moving a little and when you floor it you will spin the tires a bit and not bounce. the sooner you get it to hook the better off you will be.
yulan
stillcrazyinlaw is offline
post #6 of 12 (permalink) Old 06-30-2007, 04:48 PM Thread Starter
^Thanks guys, im certainly gonna try some different tactics this year, My not even pull it as im building a pulling semi to pund on instead.
Its a work truck
Ben46a is offline
post #7 of 12 (permalink) Old 06-30-2007, 06:32 PM
pontiacross's Avatar
tell us more what kind of semi. what engine, is there a series around you somewhere?
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #8 of 12 (permalink) Old 06-30-2007, 07:15 PM
I deffinatly want to know more as well, plus pics of it's current state.
Good vid, start looked tough.
06bowtie_guy is offline
post #9 of 12 (permalink) Old 06-30-2007, 08:08 PM Thread Starter
Well the Semi is a 76 white-western star. Its got a 20K front, 54K rears double frame. Its actually a salt truck now, but thats coming off and its getting cut to 170"WB. As of right now its got a 3208/Allison. Im just going to juice the 3208 and run it till it blows for the heck of it, (1st season if im lucky ) Then go with a 3406B and an 8LL. 3406 wont be really hot right away, 0R6051 charger, upgraded plungers, and recurved timing first off. There is a small series up here, the Maritime Truck and tractor pull association. www.mttpa.ca
Its a work truck
Ben46a is offline
post #10 of 12 (permalink) Old 06-30-2007, 08:12 PM Thread Starter
Opps, heres the pics, only 18,000 miles on it, and actually never had salt in it, just urea, its in really good shape. good score for 1500, considering i was offered 8K for the spreader
ID:	10963   Click image for larger version
Its a work truck
Ben46a is offline
