Any one try this yet?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SmokingIDI_7.3L, this thread has received 13 replies and been viewed 855 times.
post #1 of 14 (permalink) Old 06-23-2007, 04:31 AM Thread Starter
I am going to start building a sled puller and I was thinking on running a 1990 F250 super cab put a 3208 with twins allison tranny and atlas t-case dana 80 rear and dana 60 front, 33x14.50's and of course detroit lockers any comments or ideas would be helpful.
Thanks,
Scott
SmokingIDI_7.3L is offline
post #2 of 14 (permalink) Old 06-23-2007, 04:41 AM
pontiacross's Avatar
what kind of class are you going to be pulling in?:shrug:
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 14 (permalink) Old 06-23-2007, 05:10 AM Thread Starter
Thats kinda what im trying to figure out i dont know the classes and i still want my truck street legal
post #4 of 14 (permalink) Old 06-23-2007, 05:03 PM
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
If you pull with the club I am part of, her are the rules, and also we will be having a few pulls in WY this year www.unitedpullers.com
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
post #5 of 14 (permalink) Old 06-24-2007, 05:18 AM Thread Starter
that link didnt take me to any thing to do with sled pulling is that the right link
post #6 of 14 (permalink) Old 06-24-2007, 05:21 AM Thread Starter
if i went with a cummins what year is the best and what kind of power can i get with out spending a fortune and what tranny is the best behind it.
post #7 of 14 (permalink) Old 06-24-2007, 06:05 AM
TDG Mafia 36
sorry, its www.unitedpullers.net Its a habbit to put .com...
post #8 of 14 (permalink) Old 06-24-2007, 06:11 AM Thread Starter
thanks
post #9 of 14 (permalink) Old 06-24-2007, 05:29 PM
stillcrazyinlaw's Avatar
Images: 3
If you go with a motor other than a motor that came in a pickup IE: powerjoke,cummins,duramax, you will most likely be running in an exibition class. most organizations run that way. Go with a cummins 12 valve motor 94-98, easiest to work on and make power. you can get 500-600 hp pretty easy and not that expensive. If you want to spend some money you can get over 1000 not that hard.Or use alot of nitrous. You can get a built dodge auto that will handle the power as well,around $5000-$7000,unfortunately that is a big expense,but it will still be street legal and be fast as hell and alot of fun to drive.
yulan
stillcrazyinlaw is offline
post #10 of 14 (permalink) Old 06-25-2007, 12:51 AM Thread Starter
would a nv4500 hold up with a DD clutch? I was reading the united pullers rules and my pickup would not work it has a flat bed andit looked like the pick ups must have all their sheet metal. i might have mis read it though
