Broke the truck at Galax pull(pictures) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mrector, this thread has received 6 replies and been viewed 738 times.
post #1 of 7 (permalink) Old 07-10-2007, 06:42 AM Thread Starter
mrector's Avatar
Well all was going well at the Galax pull, which turned out to be a great success. :Thumbup: UNTIL, a few other guys and myself broke stuff, the right side of the track proved to be the "breaking" side. Guess which side I took I got the rear U-joint, actually one bolt on the strap failed and "threw" the shaft out, ended my night early. But, check out the smile on my face in the last photo, classic...... laugh
Gonna try and get some video and more pictures up soon. These pics are courtesy of a friend off of DTR, thanks.
Mikey
89 w250 project truck
mrector is offline
post #2 of 7 (permalink) Old 07-10-2007, 03:30 PM
diesel_ram_man's Avatar
Images: 6
Looked like you launched pretty hard. I remember when you got out of your truck at smokin after you broke the output, and you were laughing then too.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #3 of 7 (permalink) Old 07-11-2007, 12:15 AM
Nice photo's enjoy them, looks like its time for an upgrade.
#23 Singles Club
thejdman04 is offline
post #4 of 7 (permalink) Old 07-11-2007, 01:49 AM Thread Starter
mrector's Avatar
I would upgrade but this one isnt pulling anymore, that was the last time. The 91 is getting the "treatment" and will be a sled-puller. I'll just drag race and tow with the 97 from here on out.
mrector is offline
post #5 of 7 (permalink) Old 07-11-2007, 04:03 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
Aw come on Mikey, that is a little cheaper only drag racing than dragging and pulling. Fix it and try again! It did look like the frame was seeing some stretch in the middle. Nice run either way!
Putco light bar
Dieselwrencher is offline
post #6 of 7 (permalink) Old 07-11-2007, 05:26 AM Thread Starter
mrector's Avatar
Yep it was "bowed" up a little, I probably will pull a "couple" more times this summer. Just not hard-core, and probably no hanging weights.
mrector is offline
post #7 of 7 (permalink) Old 07-11-2007, 05:34 AM
I just want to get my turd running right and pull atleast once before it snows.
Putco light bar
