pulling hitches? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SmokingIDI_7.3L, this thread has received 11 replies and been viewed 1363 times.
post #1 of 12 (permalink) Old 07-14-2007, 11:44 PM Thread Starter
pulling hitches?
can some one post pics of their hitches or tell me where to get one or how to build one?
Thanks
Scott
SmokingIDI_7.3L is offline
post #2 of 12 (permalink) Old 07-15-2007, 12:16 AM
I was thinking of posting a similar question....thanks bigpete.
Can a person use 2" hitches like this?
http://www.reese-hitches.com/WD/dt_wd_hitch_parts.html
Would you use the welded kind or the forged one-piece?
Not sure if you have to upgrade to the 2 1/2" Class V hitch?
TheBac is offline
post #3 of 12 (permalink) Old 07-15-2007, 03:10 AM Thread Starter
Can u use your receiver? and just have to have a custom hitch? or what is the general rules on this. Please post some pics of what is ok.
Scott
post #4 of 12 (permalink) Old 07-15-2007, 04:20 AM
mrector's Avatar
Most local rules we run by are "have to hook from a factory style reece hitch, 2" or 2.5" reciever". No modified pulling hitches allowed, but are OK in MOD class. We use some similiar to the ones THEBAC posted(the one on the left with a big clevis). Or just use a solid tubing, drop hitch with at least a 3" inside hole twisted clevis. I used the twisted clevis set-up for couple of seasons and we only broke one due to the "hollow" thin wall tubing.
Mikey
89 w250 project truck
mrector is offline
post #5 of 12 (permalink) Old 07-15-2007, 06:09 AM
pontiacross's Avatar
This is what a buddy and I are running on our trucks
Attachment 12218
Attachment 12219
Attachment 12220
I have about $85 invested in mine I got the 3in pintail hitch and channel that it bolts in, at local welding shop for about $65. The other $20 was for the grade 8 bolts and other metal. I used 2x2 solid stock to slide in the receiver and since I have a good heavy aftermarket bumper I put and extra brace off it to help it hold better. My friend is just running a factory bumper so we extended the hitch out a little more and just added some extra braces off the piece of 2x2 stock.
ID:	11165   Click image for larger version
ID:	11166   Click image for larger version
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #6 of 12 (permalink) Old 07-15-2007, 07:24 AM Thread Starter
thanks that was what i was looking for
post #7 of 12 (permalink) Old 07-16-2007, 01:16 AM
Most run what ponti is showing, cause you can adjsut the hitch height dpeending on the rules. You many need to upgrade to say a towbeast hitch if your making lots of power. Factory hitches dependin ont he truck may only be rated for 10-12k lbs.
#23 Singles Club
thejdman04 is offline
post #8 of 12 (permalink) Old 02-05-2008, 12:34 AM
eep diesel out of ohio sells both the hitch and a weight bracket
www.enterpriseengine.com is their website
jd_craft is offline
post #9 of 12 (permalink) Old 02-05-2008, 02:58 AM
I Know where there is a bent hitch that I am pretty sure came from there is (it looks just like theirs any way, and I think that's where he told me he got it) any way I bet he'd sell it real cheep It only lasted 2 or 3 hooks with a wheel hopping powerstroke
Ross
Tow Rig
post #10 of 12 (permalink) Old 02-05-2008, 03:36 PM
Check out the competitiondiesel.com forums and look under sled pulling. There is a big thread goin on right now with lost of pics of pullin hitches.
Kyle
imported_6.0superduty is offline
